**Skip to my youtube video link if you don't want to read my description below - it basically shows me going through the same question I typed out below**
Hey everyone,
Thanks to some valuable input from the folks here, I've got my 10L 5C lever closer ready to install and use for the first time.
All parts on my unit are OEM South Bend, and all parts move freely and function correctly as far as I can tell. I fully disassembled, cleaned and lubed everything, and fixed a couple of issues up to this point with the drawtube itself and a stuck clutch stop.
NOTE: I do not have the unobtanium special backgear with the extended sleeve and broached keyway that mate with the lever closer clutch stop, as my lathe didn't come with one. My plan is to eventually machine and press on a sleeve, but I don't believe that it is necessary for basic setup and function testing of the lever closer, which is all that I'm trying to accomplish right now.
I was struggling for a while with getting the expected "lock up" and cam action, which seems to be a theme from some other threads I dug up here. But I think I figured it out. Just want to make sure I'm doing this correctly, as I can't seem to find any good existing videos on youtube showing setup and operation.
What I believe is done to set the lockup/camming action is simply loosening or tightening the drawtube itself into the 5C collet, via the collar that is installed on the end of the drawtube (part #30 in the SB literature). That collar is threaded onto the drawtube and held to the tube via a set screw (#9) and shoe to prevent damaging the OD threads on the drawtube (#8). I find that if the drawtube is too loose in the collet, then the yoke cone (#35) will contact the nesting collars (#30/31) without lockup. If I have the drawtube threaded too far into the collet, then I can't actually get the yoke cone to even contact the nesting collars. If I have it just right, I get the expected camming action and then the lever smacks past the cam point, and into the nesting collars and stays in place.
Is that correct? I uploaded a video to youtube here showing what I am speaking about above:
What's the purpose of adjusting the location of the nesting collars? It seem like they just act as backstops for the yoke cone after it cams past center, vs actually having any influence on the lockup strength.
Hey everyone,
