Solar1971
- Feb 18, 2014
- California
Hey guys.
I'm just here to do a reverse rant. Lol say good things about our new cnc machine.
Dude. This thing can do things I only thought were possible with a y axis. Without a y axis.
Ok. Imagine round stock In the chuck of a machine.
This material is 5 inch OD, 3 inch ID.
We need to make 2 key ways in the X axis. 180 %%d "degrees" apart. That was an autocad joke by the way. Anyway. Our end mill is 1/2 inch. But the key way is 5/8 wide.
So how does the machine make the key ways wider in the y axis without a y axis.
If it used the C axis to rotate the part slightly the side walls Of the key way would be tapered. Not straight. They need to be straight.
So this machine will cut along the x axis while slightly rotating the C axis ever so slightly back and forth in concert... At the same time while doing all the math internally. Trigging out everything it needs and executing it in real time.
BAM the part is done with a 5/8 key way and all walls perfectly straight. WTF!!!
This thing is amazing. All I did was tell it I have a 1/2 EM BUT I WANT A 5/8 key way in the Y axis which you don't have mr machine but I don't care. Just make it happen.
And like magic. It's done. What's the next modal gonna do? Make me coffee and rub my back?
