He cut off the last two digits on the serial number. Those tell you the year. Should be 6193-XX.Guy local to me is selling a 16x54 Pacemaker, ser CO RN 6193. 10hp, 2000rpm, D1-? spindle...
Does this ring a bell with anyone?
Don't hold me to this, but as I remember they put the two-speed motors only in the smallest Pacemakers, and usually if they had the 9 or 18 speed gearboxes rather than the 27 speed box.My 1946 14x54 has a 10 horse, two speed motor.
Jump on it. Now.If the machine is in good condition would 3k be a good buy?
What's the tailstock taper on these, #4?
Programmed via Mazatrol
Will my CXA work on it or should I be looking for a CA?14 / 16 / 20 light were MT4. 20 heavy is MT5
Stick a pair of 123 blocks under it for the time beingCXA was the right size for my 12 (14 1/2 actual) P&W. Sounds small for a Pacemaker 16 (more for actual like 18 1/2)
Mine is an 18 speed. I believe it had the two speed motor installed because it was ordered with a relieving attachment.Don't hold me to this, but as I remember they put the two-speed motors only in the smallest Pacemakers, and usually if they had the 9 or 18 speed gearboxes rather than the 27 speed box.
I have a Dorian CXA on my 14". It works well for my use, but I'd want a CA if I was doing a lot of heavy work. I think it would definitely be too small for a 16" machine.Will my CXA work on it or should I be looking for a CA?
