Hi, I run a Sodick ALC600G wire EDM.
About to make 90mm tall punches with high accuracy and straightness requirements.
I got the BSA taper correction dialed in and the workpiece is now at the same diameter at under +/- 0,001 mm top vs. bottom. I added the Anti-Barreling bit to the BSA code.
Cutting values look like this:
( Search Data : SL,Water,D0.25mm,Brass,Steel,H90mm,Punch,Close,2.6,3orMore )
( ON OFF IP HRP MAO SV V SF C PIK CTRL WK WT WS WP PC SK BSA )
C000 = 012 014 2215 000 240 +040.0 8.0 0025 0 000 0000 025 160 080 045 000000 000000 110000
C001 = 014 015 2215 000 252 +020.0 8.0 0028 0 000 0000 025 160 122 063 000000 000000 210015
C002 = 002 009 2215 000 000 +053.8 5.0 1065 0 000 0000 025 180 122 240 000000 000000 310027
C003 = 001 014 2210 000 000 +025.3 2.0 1066 0 000 0000 025 180 122 240 000000 000000 410015
C004 = 019 020 0504 000 000 +026.0 6.9 1097 0 000 0000 025 180 122 240 000000 000000 510030
C905 = 100 000 0001 000 000 +017.7 6.5 5020 0 045 0000 025 180 122 240 000012 000006 610020
H000 = +000000.010000
H001 = +000000.245500
H002 = +000000.175500
H003 = +000000.148500
H004 = +000000.137500
H005 = +000000.132500
H999 = +000000.000000 ( Taper Offset )
(To the BSA code I changed the second digit from left from zero to one on each line to activate anti-barreling function. Also added 10 units to the right hand end of the code to correct 0,001 degrees. )
TP92.0
TN0.0
N00001 G90 G55 G00 X0.0 Y0.0 U0 V0
Z0
N0003 T91 (Thread Wire)
QAIC(2,1,0.1250,011.5,0.1725,0.0800,031.0,0006,0022,20,035)
SFCC00070090
etc...
So, if I understood correctly, the antibarreling is in use, but I now get 0,004 mm bigger OD measuring at the center of the piece compared to either end of it.
Can I adjust the effect of the function with TLR like the Sodick guide says?
How much should I punch in it?
It says on the guide it's unit is % and range from -99 to+999. Percent (%) of what?
Someone said I should adjust SV instead, but I'd rather try if the Anti-Barreling really works.
TP92.0
TN0.0
Z0
SFCC00070090
etc...
