antique lathe?
maka_ca
Feb 3, 2019
Hello
It is my first day here.
Could you help me identify the lathe? Producer or year? or any information?
I bought it couple days ago. Unusual thing. It is 3' long. The chuck about 3" and welded to the back plate. The tail stock base is broken and pieces missed. The bull gear badly damaged and a bracket from back gears is missed.
Not sure why i took it. Maybe it was cheap. I have no an answer.
More detailed pictures old lathe - Google Photos
Thank you
Maxim
Sorry for my English it is my second language.
m-lud
Sep 4, 2016
I can't identify it but if you have all the pieces of the tailstock base you may be able to repair it. Welcome
Metal-Masher
Dec 5, 2018
Bienvenue-
That is a great looking lathe. It looks very old, maybe late 1800's or early 1900's. Have fun with it!
maka_ca
Feb 3, 2019
I have a quarter of the tailstock rest is lost, but it helps me understand how it was located on the ways and how adjusted. But i still do not understand how to lock to the bed.
Thank you
maka_ca
Feb 3, 2019
I am not sure about it is original paint. At the back side under green paint i can see kind of a sticker. Now i am confused - sandblaster/ paint steeper/ wire wheel/ ultrasonic bath.
m-lud
Sep 4, 2016
The tailstock would have had a bar/clamp that went across the underside of the ways that was attached by a long bolt up through the tailstock. When you want to lock the tailstock you would tighten a nut on the tailstock that would pull the clamp up against the bottom of the ways clamping the tailstock in place.
Most other lathe's are similar to hold and lock the tailstock. Look at a South Bend and copy that method of attachment.
Google electrolosis for rust removal. It's fairly easy.
cncFireman
Jun 19, 2013
Farmington Missouri
Based on the features it may be a 1860s-1880s or so lathe. Hard to say for certain. It has some basic lathe features that will make identification of the builder likely impossible if there are no markings. Nice lathe. Can be repaired don't scrap it.
Jim Christie
Mar 14, 2007
L'Orignal, Ontario Canada
That’s an interesting little lathe.
Somehow I think I have seen a sketch of a lathe similar to this one in an old magazine or catalogue on archive.org or the Hathi Trust Library but can’t think of where I saw it.
The short feet under the bed are a little different than I remember seeing on many small lathes and the spindle bearing caps look similar to some I have seen on larger lathes.
If you are located in southern Ontario there is an off chance that maybe it was something that was made by one of the local machine builders like MacDougall in Galt or McKenzie in Guelph. etc.
Although most of the machines I have seen from them are larger.
I’ll try and post a link if I find anything .
maka_ca
Feb 3, 2019
The tailstock would have had Look at a South Bend and copy that method of attachment.
You are right - i have SB9A i will check on it. BTW do you know how check serial number of SB lathe
I know what is electrolysis - i did clean a gas tank on my vintage yamaha, but i do not have so big container.
Thank you
m-lud
Sep 4, 2016
Thank you
SBL Serial Number File
I used a storage tub/container for electrolosis.with smaller parts. Old Bath tub?The SBL Workshop
There is a lot of south bend information to search through.
South Bend Lathe Works - Publication Reprints | VintageMachinery.org
There is a serial number page that south bend owners have sent to Steve wells.
If you want a detailed card showing the serial number information you can order the data card from Grizzley on your lathe. They bought south bend. It will Cost you $25. 20181112_083757.jpg I ordered this one for my S.B.
This is what you get. I'm not sure how old your 9a is. They only go back so many years.
You may be able to modify a S.B. or other tailstock base to fit your other old lathe. Try to match your ways.
m-lud
Sep 4, 2016
iwananew10K
Sep 12, 2010
moscow,ohio
if it is in fact Gardner do not give me credit for anything other than googling, it was Jim Christies posts that prompted me to dig deeper....still can't get the links to work, but found one that really seems to be a dead ringer, likely googling in French(OPs first language?) will net much more.
Jim Christie
Mar 14, 2007
My image searches are only turning up the larger lathes in my older thread.
I had seen pictures of another I think small Gardner lathe on line some time ago perhaps on an other forum but can’t seem to get it to turn up now.
The tail stock looks similar on the larger lathe but the barrel clamp is centred over the barrel on the larger lathe but off to the back on the one that is the subject of this thread.
Maybe you can type in the link address to a post of the image you are seeing and we can search for it that way if you can’t get the link to work.
I’m thinking that I have seen an image of a lathe very similar to that somewhere but after looking at so many old pages over the years I’m be ginning to loose track of them.
I was thinking that the lathe might also have been a shop built machine either as a school project or apprentice project in one of the larger perhaps railway shops that had apprentice programs .
I noticed this pdf document about Canadian machine tools when I was searching last night that I don’t recall seeing earlier .
See link below
It would appear that there a lot of shops that made lathes in small quantities for their own use or limited sale but by what I can see most would have been in the 16” to 24” swing size.
Regards,
Jim
https://documents.techno-science.ca...ustry-MachineToolsinCanada-1809-1960-2000.pdf
P.S.
I tried a search in French
Here is another Gardner wood lathe that I may have seen before.
LaMortaise.com - Vieux tour - LaMortaise.com - La reference en ebenisterie
Still not the one I had in mind
Sirjeffrey
May 13, 2019
Inherited antique Railway Lathe
We recently inherited an antique F. E. Reed Co Railway Lathe from Manning, Maxwell, & Moore. We believe it is worth far more than just scrap.
We are looking for someone who will embrace it as much as it’s owner. I have pictures once I figure out how to post them.
fciron
Oct 14, 2009
Louisville, KY, USA
You should definitely start a new thread for your lathe. Lots of folks might click on "Help with FE Reed lathe" who will barely glance at yet another "Identify an old lathe" thread.
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
QT :[I have a quarter of the tailstock rest is lost, but it helps me understand how it was located on the ways]
From here it looks like the clamp for the tail is the second thing on the bench, and all you need is a bolt.
The flat bar with a hole at center.
Be sure both side of the spindle are getting oil, pick clean all chips and oil everything with a drip oil can and a rag...Not a spray can of WD or the like.
Don't wire brush numbered dials.
alum100k
Jan 17, 2019
Lathe ID
it looks like the backplate is a drum and the chuck was welded to it. Who does that? Automotive shops. Engine lathes were at one time part of a package of equipment. Can't say for certain but Bear, Armstrong and others made lathes which were not brake lathes.
