Id like to have a hand drill that will take 1/16” or less twist drills that can drill parallel to interference 3/16” from drill chuck axis. My Dremel flex shaft handpiece is too large in diameter. Here’s an example of a job where I could use this. The rapid elevation handwheel mounting, cast iron, of an Abrasive 3b surface grinder was broken off by a newbie with a hammer. I know I could take a day and disassemble the top of this machine to get better access but it’d sure be nice to have a drill that’d make three reinforcing pin holes parallel to the steel shaft shown. A typical dental handpiece probably has small enough throat/clearance to do it but they all seem to need a separate power box and work at way too high rpm and too low torque. Anything available reasonably, like under $100?
