Any PM members that have infrared wireless probing on VMC ? If so...do you know how the receiver is interfaced to the control ?
Milacron
Super Moderator
Dec 15, 2000
SC, USA
In this case, Hexagon system with Fanuc 0iF control... but interface may be similar to Renishaw. Does the receiver connect to a separate power supply in the electrical cabinet ? And where does it connect to the control ?
And perhaps a separate thread... but is there probably Hexagon software interfaced to the control.. or does Fanuc have probing functions built in that recognizes the Hexagon probes ? (in this case there are two..table mounted one for tool offsets/diameter and CAT40 one for part probing)
PROBE
Jan 23, 2003
Tel Aviv, Israel
Which hexagon (m&h) system ? Could you attach the picture of the receiver ?
Stefan
Cogito Ergo Sum
Milacron
Super Moderator
Dec 15, 2000
SC, USA
Stefan
Cogito Ergo Sum
Curiously, the "operating instructions" provide zero info on actually using the system once installed and adjustments made.
usolutions
Nov 25, 2020
Riga, Latvia
I guess it is up to machine manufacturer to setup integrate macros into controls. Also where to pick up power is up to machine manufacturer, not control/probe manufacturer.
Technically it can be retrofitted, and macros can be handwritten manually afterwards.
PROBE
Jan 23, 2003
Tel Aviv, Israel
1. Is the system installed and connected to the control ? If not, here https://www.system3d.pl/pub/download/instrukcja-obslugi-sonda-hexagon-m&h-IRR91.50.pdf you can download the installation instructions and data.
2. Does the system include both the tool setter and the touch probe ?
3. If the system is installed, are the measuring routines files present in machine control ?
Stefan
Cogito Ergo Sum
BOB-OO
Dec 5, 2010
NE PA
I installed the Renishaw RMP-Q?, probe and tool setter in a Kitamura w a F16iMB.
The MTB will list the board connections in the electrical diagrams. It doesn't connect to the "control" directly, the MTB IO board interfaces power & the skip signal to the control. We also used the provided relays for power to the radio. It took about 8hrs for probe & tool setter with the complete electricals never having done it before.(not too hard)
