Any potential issues with programming helical interpolations like this? Fanuc
KYLET3
Sep 22, 2023
Fairly new to using fanuc controls and I was wondering if a program I put together here would be a viable option for helical interpolation. I have tested it a couple times with promising results however I would like to add some error traps or necessary edits if there is anything here that you all see inherently wrong with it. Thanks for any help.
Main Program
O2416 (ADJUSTABLE INTERPOLATION MAIN)
G00 G80 G40 G17 G20
G00 G90 G54 X0. Y0. W0.
(EDIT VARIABLES)
#100 =5. (BORE DIAMETER)
#101 =1.0 (BORE DEPTH)
#102 =.1 (DEPTH OF CUT)
#103 =4. (CUTTER DIAMETER)
#104 =60. (HELICAL FEEDRATE)
#105 =450 (SPINDLE SPEED)
(CALCULATIONS DO NOT EDIT)
#110 =[#100-#103] /2 (Y AND J VALUE)
#111 =ROUND[#101/#102] (NUMBER OF LOOPS)
G00 G80 G40 G17 G20
G00 G90 G54 X0. Y0.
G00 Z10.
S#105 M03
G00 Z1.
G01 Z.1 F50.
G01 Y-#110
M98 P2417 L#111
G00 G90 Y0.
G00 G90 Z20.
M30
Sub Program
O2417 (ADJUSTABLE INTERPOLATION SUB)
G91 G03 J#110 Z-#102 F#104
M99
This is what while loops are for:
#111=#102( FIRST DEPTH OF CUT )
WHILE[#111LE[#101-#102]]DO1( LOOP UNTIL 1 PASS TO BOTTOM )
G03 J#110 Z-#111 F#104( HELICAL INTERPOLATION )
#111=#111+#102( NEXT DEPTH OF CUT )
END1( END LOOP )
G03 J#110 Z-#101 F#104( FINAL HELICAL PASS )
G03 J#110( FINISH BOTTOM )
G01 Y0( MOVE OFF WALL FOR RETRACT )
Doing it this way you will always hit your depth even if the final depth isn't evenly divisible to the depth of cut.
If I was going to make a macro for helical interpolation I would think about having it calculate the arc adjusted feed for the circle dia/cutter dia and be able to just enter in the tools linear feedrate.
Helical-interpolation option not available?
You are able to use helical interpolation but this control does not recognize L variables on a G03/G02 line. So you have to manipulate it either with a macro or a subprogram in order to have it loop the helical motion.
You may call G02/G03 multiple times, once for every 360 deg motion. Only Z needs to be specified in subsequent calls.
If there are too many loops, some repeat method would be convenient.
Even Fanuc does not allow L address with G02/G03.
Thank you for your input I appreciate your help. I think my confusion comes from the other fanuc controlled machines in our shop allowing you to program interpolations as follows.
Example
G03 J1. Z-1. L10 F50.
Resulting in the machine swinging a 2 inch diameter 10 times and travelling -0.1" in Z each revolution. Where you end up at Z-1.
