Anyone have a QIDI TECH X-Plus 3D Printer
pcasanova
Mar 14, 2008
vacaville ca
yes, when it works it seems to work great but I have issues with the nozzles plugging up. printed all week no issues, finished one print, printer sat for a few hours started the next job and it was plugged (not the first time). took the print head apart cleared the clog now the print head wont heat over 175c. plugged in another extruder and same issue. both heads had 14ohm resistance and 23v feeding. emailed tech support and they wanted a video, really don't know what a video will prove that after 10minutes the temp only hit 175. Not sure where the failure but it seems parts are available. they have a ebay/amazon/ali stores.
jhov
Jun 5, 2020
SW Ohio
I have the X-MAX and have had no issues. It's dead simple to use and produces good prints right out of the box.
Deude-Mann
Mar 27, 2021
I have two X-Plus machines I have run about 50 kilos of filament through and they work just fine. It was recommended to me by a friend that uses several Qidis for production work.
Facebook has a good Qidi user's group.
Pietro8
Apr 28, 2021
Pros of this printer: large print area, fully enclosed body, 2 spool mounting options, 2 network interfaces, built-in backlight, ability to turn off the printer after printing, magnetic table with good adhesion and easy part separation.
Cons: High price
What do I lack in this printer to call it perfect, in terms of usability? It needs a quieter driver and a double-sided part blowout.
Leif820
Sep 30, 2021
I have 3 at home and works has bought 3 I also have their UV cure printer as well. They are awesome out of the box with little adjustments. Simple to use and reliable. I run the home printers nonstop all week and the work printers run 24 hours a day. in 2 years we have had no issues other then operator error. Their new I-fast is amazing with beautiful registration at 25% faster speeds.
Hope this helps
no704
Sep 14, 2017
Tempe, AZ
We have 2 X-max units. They work great! Need to re level the bed occasionally. Have had to change the print nozzle a few times, keep extras on hand.
DubbleTrubble
Feb 8, 2021
Hollyweird CA
I realize this is an old thread, but it caught my eye because I just purchased a Qidi X-Plus II. I've been using a Prusa Mini+ for about 15 months now, and needed another printer to increase production and also easily get into nylon and polycarbonate. I've only been using the Qidid for 5 days thus far, but have already developed some opinions:
  1. It makes nice prints and is pretty easy to set up.
  2. I haven't had any clogging problems so far.
  3. So far, I prefer to use the Prusa Slicer rather than Cura or Qidi's version of Cura. This may be because I've been using the Prusa slicer for a year and am comfortable with it.
  4. Speaking of Slicers, the standard setting gcode from Cura seems to take about 2-3 times longer to print than that of Prusa. For example, the same exact object printed with the basic Prusa slicer takes about 2.5 hours to print. With Cura, it's closer to 5.5 hours. Both with a layer height of 0.15mm. I printed both and there is no noticeable difference in quality. I haven't looked too closely at the gcode yet, but I did notice that the print speeds aren't all that different. I mention this because, if you're new to 3D printing, you might not realize how long the prints made by Cura are compared to Prusa. Or maybe I'm missing something.
  5. The X-Plus II comes with two separate extruders for low-temp and high-temp printing. The low-temp extruder has an MK8 M7 nozzle and the high-temp a MK10 M7 nozzle. I've been trying to find a source for the MK8 M7 nozzles, other than Qidi, and it's not been easy. I need 0.6mm for a specific project. The original X-Plus low-temp extruder had an MK10 M7 nozzle. I don't yet know why they made the change.
  6. For $610 including tax and shipping, what I paid at an 11-11 sale, the Qidi has a lot of bang for the buck. I'm impressed. The customer service has been good so far. However, I'm questioning the choice of the MK8 M7 nozzle.
50BMG DUDE
Jun 17, 2013
Bonners Ferry
We've got one and I absolutely love it! - have not had ANY issues with it (yet) We use Simplify 3D for slicer and Solidworks for modeling. My Son bought us a bit bigger nozzle than it came with (.6MM I think?) Prints bigger prints way faster, but still really nice prints. Kinda like running .012 wire on a Wire EDM, (cuts way faster because it carries more juice)
4GSR
Jan 25, 2005
Victoria, Texas, USA
My son bought this printer at the beginning of summer. Did great until he ran some filament through the print head and it clogged up. He unclogged it and eventually got it back to running. He went ahead and bought a new print head for it that is supposed to be a bit better than the one that came with it. We've run several different materials thru it including one of the polycarbonate nylon filaments for printing a couple of gears.
He changed out hte platen with a piece of Garloc sheet we purchased from McMaster-Carr and took a bit to get it adjusted out level and has been working out very good.
william88
Jan 10, 2023
Anybody Print with Priline CF PC on Simplify 3d? I have a Qidi Tech Xplus and have Been through about 10 rolls or so just fine getting good prints. Bought 2 more rolls from here and both machines I have are doing the same thing looks like a build-up of filament on the nozzle is causing the print to get caught on the print and causing supports not to be printed as well as defects in the walls of the part.
I have leveled the bed, calibrated the flow rate, and new nozzles ( tightened them while is was heated). Wondering now if its a filament issue. I can try and dry out the filament but this was never an issue before and these are brand-new seal rolls (if that means anything).
DubbleTrubble
Feb 8, 2021
Hollyweird CA
I does sound like it could be a filament issues, but I have had printer problems with my Prusa Mini+ that manifest like filament issues. Have you tried running another type of filament through your printer, just to confirm whether it's printer or filament related?
DubbleTrubble
Feb 8, 2021
Hollyweird CA
5. The X-Plus II comes with two separate extruders for low-temp and high-temp printing. The low-temp extruder has an MK8 M7 MK10 M7 nozzle and the high-temp a MK10 M7 nozzle. I've been trying to find a source for the MK8 M7 nozzles, other than Qidi, and it's not been easy. I need 0.6mm for a specific project. I received incorrect information about this from Qidi. After much back and forth, both extruders use the MK10 M7 nozzle. The original X-Plus low-temp extruder had an MK10 M7 nozzle. I don't yet know why they made the change.
I can't edit my original post, and wanted to update it.
