SteveM
- Sep 22, 2005
- Connecticut
Here is an assortment of odds and ends (is that repetitive and redundant?).
All prices are exclusive of shipping. Shipping will be flat-rate box unless it makes more sense to use something like a padded envelope.
If the picture shows a bunch of something, the price is for the bunch and not each.
Payment by paypal for "goods and services", not "friends and family".
Preference will be given to long-time board members.
A - lot of seven 3 morse taper dead centers. All need to have tips reground.
$5 for the lot
B - set of four 4C collets in 64th sizes - 9/64, 7/64, 11/64 and what appears to be 5/64
$20
C - Vintage 5C drawbar collet closer with wood handle. handle is cracked and needs to be repaired or replaced. see pictures for all dimensions.
$50
D & E - Metric drills - Walter Titex 20mm drill bit. It has a split point, 118 degree point. The cutting edge has a primary and secondary relief ground in. It looks almost new and is very sharp.
Hartner 21.0 mm HSS drill bit, MT2 shank, black oxide, appears to be new and unused.
$25 (sold together)
F - Lathe Chuck Backplate 2-3/8 x 6 tpi, 6-1/4" diameter, fits some (but not all) South Bend 16 and
14-1/2. The backplate has a total thickness of 1-3/4" with the perimiter 0.919" thick. The register
is 4.719" diameter and about 0.100" thick.
$50
G - Brown & Sharpe #9 BS9 End Mill and Woodruff Cutter
The Woodruff cutter is 1.125" diamter and 0.379" width, which looks like it's for a 1210 Wooddruff key. The shank is marked "Brown & Sharpe Mfg. Co. Providence R.I., No. 34L High Speed Bit".
The end mill is 1.25" diameter and 2" length of cut.
$10 for both.
H - Tapered end mills, HSS, 1" shank, 3 are are tapered 3 degrees and one is tapered 5 degrees.
$15 for all.
I - Grenfield HSS TiN-coated 1/2-20 bottoming taps, new old stock and very sharp. GH3 class of fit.
$30
J - Lot of four 151.2-25-50 parting blades, believed to be for T-Max Q-cut inserts
$40
K - Ten Guhring 3/8-16 2 Flute Spiral Flute Taps. Appear to be unused and are very sharp. The taps
are marked: "C-3/8-16UNC-2B 45 degree-31.5 hss-E GUH LVNL V"
$75
L - GAR S-22 Microfinish Surface Comparator
$25
M - Kalmaster 0-6" Caliper Master for checking inside and outside jaws and jaw frames. Dimensions
are specified to 0.0001". Original wood storage case included.
$100
N - Precision Devices Reference Standard PDR-6 for calibrating surface roughness gauges. It has separate surfaces marked "Calibration", "Linearity" and "Stylus Check". New price is $350
$50
O - Starrett #494-b toolmaker buttons. These are size B in the set of four, the second smallest set. They are on the original base. One of the four screws is not original.
$20 or will trade for a Starrett #494-c
P - Tungaloy JSTBR1212K3 B47 right hand lathe carbide insert toolholder, 1/2" shank, 6" long. Takes a Tungaloy JTBR 60 degree triangle insert with a 45 degree lead angle. The insert presents a VERY sharp cutting edge to the work.
$30
Q - North American Tool Tru-Flo 13/16-20 thread forming tap for aluminum. The shank of the tap says: "North American
11/16-20 NEF HS GH-8 Tru-Flo Aluminum USAS 1Z10"
$25
$5 for the lot
$20
$50
$25 (sold together)
$50
$10 for both.
$15 for all.
$30
$40
$75
$25
$100
$50
$30
$25
