Automatic Threading Stop on SB Heavy 10
MrWhoopee
Nov 8, 2017
Good point. Oil is constantly being supplied up high and it slowly flushes down into the sump.
It sounds like you have played with different spring tensions, any chance of providing a source/part number for the spring you ended up using on the retractor arm?
A little crude testing with a 50 lb. scale indicated I needed about 20 lbs. of pull while exerting pressure against the half-nut with the handwheel. I found my spring at True Value, but this is the same.
So far, I've only tested up to 3/4-10. At coarser pitches, the pressure against the half-nut increases, both due to the greater travel per rev and the larger face contact (=chip load) nearing the finish. Planning to try 1-8, which is as coarse as my threading inserts go.
BKahler
Jul 2, 2006
Richmond, Kentucky USA
Thanks for the spring info.
Later this year I have to turn a 4 tpi acme thread. I wonder what kind of pressure this will generate on the half nuts. Probably considerable.
MrWhoopee
Nov 8, 2017
Yes, but it can be reduced substantially by reducing the DOC on each pass. I would definitely be using the compound and not trying to feed straight in.
dullvinci
Aug 26, 2004
Fla
Very true. I am also considering roughing in the thread with a V tool to remove most of the metal before switching to the acme tool bit.
I have roughed Acmes using a stubby straight tool, ground with clearances to suit. Worked out well.
MrWhoopee
Nov 8, 2017
I'm speechless!
Needless to say I would really like to see the parts details for that pullout device :)
MrWhoopee
Nov 8, 2017
The retractor got some detailing this week. The reset lever was moved to the top, a new trip lever was mounted on the bottom and it got it's own dovetail to reduce overhang and free up the tool holder. As an added bonus, the height adjusting screw is perfectly postioned as a reset stop.
MyLilMule
Jan 5, 2021
Ohio, USA
Awesome job on this widget. I love it. I think I love it as much for it's usefulness as it's "I'll show you!" factor. LOL!
MrWhoopee
Nov 8, 2017
Great outside the box thinking. Keeping the slop out of that tool slide mechanism was probably tricky.
Yes, I was able to mill the slots, but lacking a surface grinder, I did a lot of lapping on the tool shank with 320 wet-or-dry. I checked the assembly and get .001" side to side movement.
