Automating low volume/high mix lathe work.
bryan_machine
Jun 16, 2006
Near Seattle
and of course robots are driven by software, and we all know how easy it is to keep that running over time, understand it in the future, and so on...
how hard can it be??
there is a multi billion dollar industry devoted to making it easier, wonder if that is an omen....
Johnny SolidWorks
Apr 2, 2013
Rochester
As usual, I'm with Tony on most all things 'Automation' - I have a different background than he does (I'm a full-time automation engineer, but I work almost exclusively with custom machine projects in the automated assembly industry) and I also happen to own a small shop of my own.
I think the first thing to know, which is absolutely critical, is that you're going to either need to hire someone who knows automation, contract it out, or commit to sending someone for robot training, and probably PLC training (at an absolute minimum.) Tony downplays just how unique he is, and how talented, but the number of people out there who can design and integrate a robotic automation cell for a CNC machine, and do it well, is extremely limited. Lots of folks can do a piece, or two, or the big piece, but finding an idvidual who has a great understanding of both the Mechanical and Electrical Engineering aspects, as well as fixture design, robot programming, EOAT design, and PLC programming (and doing it all in a way that is SAFE)....well, you're better off chasing the gold at the end of the rainbow.
If you think it's something you can just buy the pieces and figure it out - well, you'll wind up looking like a YouTube machinist who has no clue what they're doing. Except the CNC programming part of these projects is definitely not the hardest part. And there are a lot more parts.
And if you're going to invest half a million dollars or so on automation equipment, then think you'll save money by trying to integrate it in house, I'd suggest not doing it at all. I just visited a customer in Buffalo who is attempting this on a palletizer line (it doesn't get much easier) and is now paying our guys to fix all the mistakes they made, which pretty much involves going back to the start. It would have been significantly cheaper for them to buy the palletizer cell from us.
Have I sufficiently scared you yet, while proving what a superior d-bag I am? :D
Seriously, I love seeing shops get into automation. It's what I do, after all. But you're asking the question a TON of shops are asking right now: how do we automate our job shop? It's a great question, and I'm not sure anybody in the industry has a good answer yet. I've been looking at it for the last 2 years, both as part of my full-time job, and how I would automate my own shop, and have yet to find a great answer.
Honestly, with all the 'built-in' automation capabilities already in a lot of newer lathes, you'll be hard pressed to add much with a robot, especially considering you'll have to integrate that, versus buying a bar feeder, tool changer, part catcher ,sub-spindle, live-tooling, etc. that all comes in the same box.
If you want to see cool ways to use that UR on equipment that doesn't have any of those features, check out Mr. Rudolph's Instagram. Instead of buying servo doors, wiring into the controller, etc. you just make the robot do it all. Hence the appeal of URs.
I would seriously recommend having an automation company come in and do an 'automatability' study. I bet if you reached out to MotionGuru (who has experience in this field and is in the Pacific NorthWest) he could either recommend someone, or give you an idea of a price to evaluate the project.
This is normally where I pitch myself for this type of work, but you're on the opposite coast and I'm busier than I can handle right now. But if you want to reach out via email for a sanity check, I'm happy to help out here and there as I am able.
Mike1974
Nov 5, 2014
Tampa area
Low volume high mix... is it going to be slug work or bar work?
If its slug I'd look at a Nakamura NTRX300. Should be able to get 120 tools and the B axis allows simple roughing turning holders so many clearance angle positions. I wouldn't mess with a B axis with a lower turret for low volume high mix. I dont think the setup time / managing the lower turret tool positions is worth the hassle for this application.
if its bar I'd want the biggest bar capacity you could get within reason so I'd choose the Mazak integrex i100 bartec machine.
The key here is reducing the human input to change over jobs. Do you have the capacity to dovetail your raw stock? This would allow you to load slugs of many different sizes / lengths with 1 fixture that wouldn't change and it would give you great gripping force with maximum clearance. Its a lot cheaper to leave a vise setup in a vertical and prep some small quantities of blanks than change chuck jaws IMHO
Are you talking dovetailing round bar stock? Have you done this, or know anyone? Just curious as I have never seen it before, but it sounds brilliant! (assuming you have a 'v' or something to keep the stock from spinning..) :D
I think wheelie actually showed a picture one time of using talon grips, or a modified bolt head counterbored into chuck jaws to do something similar...
danrudolph
Mar 21, 2017
Thanks for the plug :-)
It’s a slog trying to run a 2-man shop and design/engineer/implement automation projects, I have two solid projects that have freed me up from machine tending. It does rely on a steady stream of repeat work. URs are the closest thing to the holy grail out there right not but not “it” yet.
Gobo
Jun 4, 2013
Oregon, USA
We have a Bartac. Nice machine, but would not buy another. The main spindle is limited to 2000 rpm max. If your process is cycle time driven, that can murder you.
dstryr
Jan 22, 2010
Nampa Idaho
Yes I’ve mounted a dovetail fixture off my 5th axis onto my 6” lathe and turned square blanks round
Panza
Oct 23, 2005
Lillehammer, Norway
Very good point there, I was thinking a Bartac would be nice since that leaves pretty large pieces (in this case) for chucking and those would probably have long enough cycle time that the automation doesn't pay off for the low volume. The smaller pieces could be run on a normal 2-spindle with a barfeeder. Anyway: a Quick Turn 350MSY also has 102mm bar capacity and it has 3300rpm, so that would work. Now it is just a case of getting the management to understand..
Spinit
May 13, 2007
Central Texas
We are a product shop that does LOTS of R and D with a huge mix of low volume production pars. Management wants automation on all new equipment we purchase. I have been instructed to begin researching a machine which will be purchased mid 2019. In particular, a CNC lathe in the 15 -20 HP spindle range, main and sub spindles (probably 8 and 6 inches) 2 to 2.5 inch spindle bore, Y axis and live tooling. No cheapo equipment wanted, something in the line of Mori or Mazak quality. No difficult material to machine, maybe a little stainless but mostly mild steels and aluminum. 20ish inch Z axis work envelope. Cost is, as always, important, but not a major driving factor. We currently have 17 CNC lathes some with barfeeders, some use barpullers. Several have part catchers. One has an integral unloading arm and parts accumulator. One machine has a gantry loader. We recently purchased our first UR10 and are awaiting delivery.
I cant help but think the low/volume - high mix situation will pose a challenge to automation. Other than the aforementioned automation we are already using, what would you recommend we consider? What words of wisdom are out there?
I do realize that automation solely for the sake of automating might not be the best approach, but this is what I have been told to do.
It would be easy to justify a bar feeder for that new lathe in case you get real busy and need that output.
that Arm is pretty neat. On your lathes how many are you using on them? Are you guys running a night shift also? You are the only person I have visited with in person or on PM who is Automating. Seems almost a waste to order a lot of extra Automation on small runs of R&D type parts for that machine. If your boss is pushing on this now is the time to investigate what is out there and go and order some more equipment. Have you been able with your 17 lathes to cut some personnel expense by using Automation so far?
Gobo
Jun 4, 2013
Oregon, USA
We purchased a Mazak lathe with a part carousel and loading arm in the late 80's. WSe used it off and on for a couple of years until it quit working correctly and we were unable to get it functioning again. The UR robot we are awaiting delivery will be the only robot we have for machine tending. We currently run 2 ten hour shifts, with a third weekend shift. Like other shops, we are somewhat being forced into automation because of the skilled worker shortage. And because of the lack of workers who are willing ( or able ) to invest the time in learning a trade. We have very successfully automated two of our high production lathes, one runs completely unattended, the other mostly so. We use bar feeders and bar pullers on several other machines. We will use the UR robot on lathe projects to begin with, and then will work on using it on the milling side. We are working with an integrator to get our feet wet, then will use our own team for following projects. We also do an enormous amount of welding, and plan on automating that portion of our work.
Spinit
May 13, 2007
Central Texas
Sorry about the worker shortage. A lot of people are done with the usual work in favor of going to pasture. It is still tough.
Spinit
May 13, 2007
Central Texas
Yeah it will move that direction for a bit. My last boss went and got a huge degree in manufacturing and automation. He even converted or helped as a intern one factory seven hundred workers and set the plant from front where raw material was loaded it flowed through each mechanical op until at the end the finished product was finished and ready to ship. Three to five guys run the thing. Essentially the CNC machines are the first step to super precise super repeatable automation of course. They replaced the need for many Machinists. Many are moving into lathes with live tooling VDI which eliminates a bit of milling type operations. The live tooling on these are not as rigid as they are driven on the tool carousel.
Plus a Integrex just blows it away for versatility and rigidity. Mazak s are the ultimate Job Shop CNC also their quality,accuracy,and the fact it is really more a Machinists machine since a lot of shops use the machinist on that machine to do it all setup and programming. To get more done more people are buying Horizontal Mills a plenty. Also with five axis mills they can save a lot of extra setups. Even Dual turns are very good especially if they are set carefully at the change of the part from first chuck to second they move and do the exchange in the middle. Automation I could see it get complicated especially with repair and maintenance on the equipment.
Tonytn36
Dec 23, 2007
Southeastern US
Automating high volume work is simple. It is the low volume stuff that is the REAL challenge.
I'll agree. I've done several systems where the order might be 4 pcs and the next order may be 50 pcs. The challenge with low volume is getting the parameters correct to being with. You cannot make a system that will run anything that comes through the door. There has to be limits (an envelope) as to what size / shape / weight / etc.
Spinit
May 13, 2007
Central Texas
Yes there definitely is a lot of industry to support it. I wonder since it may be the case that across the board all scenarios are not profitable enough to waste the investment. Gobo’s gives a very good example of where it may not be a best suited prospect for automation beyond just the CNC machine. In situations like his the focus becomes doing your best and taking your time not to scrap any parts and proving out your program and processes. Sometimes the best you can do is to set your best run for that part right and benefit by having that crucial part of the process proven and working.
There are better and worse situations in manufacturing and I know one glove may not fit all. The first thing to watch is whether the job was not underbid. I see so many examples of prudent steps to decrease run time while improving the process of making a part. I often wonder it it may be a losing situation from the start due to underbidding. If that is the basic problem then all efforts to manage better or motivate people are missing the basic problem. The adjustment or solution must be the right target.
It would seem lots of production may be a obvious qualifier. Yet then you must still make better profits and parts after your investment. Otherwise you find your self asking what your satisfiers are and whether to enjoy the work because someone says money does not matter nor pay. Ha um No.
RobotGuy22
Jun 6, 2018
READY Robotics makes a cool system that is great for low volume/high mix. And I think they rent monthly.
Gobo
Jun 4, 2013
Oregon, USA
Well, management pulled the trigger. Two identical Mori NLX 2500 SY machines. Gantry loaders and bar feeders. Quick change jaws and lots of bells and whistles. 5 years ago we purchased a NZX with a gantry loader that delivered to us everything that we were looking for, including lights out operation. With our NZX we are machining aluminum only, and the family of parts coming off the machine require nothing other than calling a different part number to change from part to part. The new machines will be required to run any of approximately 30 different parts requiring around 60 tools. Material will be a merry mix of carbon steels, aluminum and stainless. From 1 inch diameter to 3.5 inch. As my previous posts stated, the batch sizes are from a handful on up to 40 or 50. These are daily quantities. LOTS of setups. I am concerned that some in management do not understand the huge difference between what we wanted from our first gantry loader, and what we are wanting out of these. Gonna be fun!
J Gilles
Feb 19, 2016
PNW
Are you planning on any quick change tooling for them? Seems like it could makes sense with the amount of change overs you describe.
Apr 14, 2018
Airstrip One, Oceania
But they read it in an article at the dentist's office ! Automation is taking over, there won't be any jobs for manual workers anymore ! It's the wave of the future ! :D
(And has been since 1970 that I know of. Probably even earlier.)
It's kinda funny ... you hear that crap from the academics (mostly so-called economists) and then compare it to the real world remarks from people who do it.
Big difference :)
