Automotive machining question…
cosmopedro
Jun 28, 2022
Hi all! Not necessarily a machining question but am betting I’ll get an answer…
Grandson has a 2001 Ranger that I stupidly nicked a section of steel fuel line while cutting off the top shock stud on LF shock… it’s been a while since I did mechanic work so I’m rusty… anyway, I called Ford and that part is no longer available so I’m trying to figure out a workaround that won’t take an entire weekend to create.
I thought about a regular plumbing flare fitting - since I could get the flaring tool in there - but the OD of the (apparently) stainless fuel line section is about .3220 and the ID of a flare nut is .38 and change.
Is that .06 too much of a delta for a flare fitting? I want to flare both ends and insert a flare coupling…
Ideas? Buehler? Buehler? Anyone?!?
DDoug
Oct 18, 2005
NW Pa
This is "Automotive Machining" ???
Use a proper steel line, make new.
I own the double flare tool kits, bubble flare tools assorted fittings, rolls of steel line in various sizes, and several benders for brake lines.
Have done some fuel line work with it, can buy adapters
if needed.
Or you can bubble gum the job and wonder why the hood blew off
when it leaks, sprays fuel, and the resulting fire consumes the whole vehicle.
Turbowerks
Nov 9, 2018
Windom
Use your flair tool to make a bubble flair slide your hose over it and clamp that that will hold the hose on. Use fuel injection hose if the pressure is high. If you dont have that type of flair tool many auto parts stores rent or loan them.
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
I wouldn't monkey around with a split rubber hose on fuel line for a fuel injected vehicle. Pressure is pretty decent and if it leaks it could cause a catastrophe. Get the stuff to fix it right. Can you not just replace the entire small section of fuel line with replacement that you bend yourself?
cosmopedro
Jun 28, 2022
if needed.
While I appreciate the concept of “Use a proper steel line, make new” I apologize for leaving out the fact that I own a plumber’s flaring tool but not a bubble flare tool, my bad. And thanks for the suggestion!
Regarding the attitude with which you presented your suggestion, bend over: I know where to put that.
cosmopedro
Jun 28, 2022
I don’t own a bubble flare tool, and the access path to & around that line is very tight other than the few inches I managed to knick while cutting the shock stud… I like APD’s flare union approach since it’s a repair I can do with tools at hand, and not have to tear half the engine compartment apart to get to both ends of overall line…
cosmopedro
Jun 28, 2022
My flaring tool is a plumber’s compression flaring tool… and where I live the auto parts ‘loaners’ are often broken, misadjusted or otherwise unusable! I’ll try APD’s compression union approach because once I have the union I have the tools to install it on hand.
Thanks!
310 Guy
Jun 6, 2009
Rosamond, CA
Been turning wrenches for 55 years... absolutely do NOT use compression fittings on a vehicle. They work (sort of) in a house because the house (usually) doesn't move or vibrate. If used on a vehicle which vibrates, they will leak. Every time.
CutterBill
cosmopedro
Jun 28, 2022
CutterBill
OK - how ‘bout regular plumbing flare fittings? Or Loktite on both ends?
ratbldr427
Mar 21, 2006
jacksonville,fl.
Get an Ermeto or some times called a "Bite" type compression fitting coupler. Use for hydraulic fittings 3k psi and will not leak or vibrate loose. A hydraulic hose shop or any one doing hydraulic work should have some.
Look on line you should find plenty. Where are you? I have plenty of them at work.
john.k
Dec 21, 2012
Brisbane Qld Australia
There is a kind of blue rubber fuel hose that can be slipped over steel pipe and grips without extra fittings ......I use to use a lot of it with the compressors.........plenty of heat and vibration there.
DDoug
Oct 18, 2005
NW Pa
So either buy the proper tools or leave.
"Bend over" yourself wanker,
