Automotive machining question…
Freedommachine
May 13, 2020
Split a short piece of rubber fuel line and clamp it in place.
^^^this.
My 95' wrangler got a small hole in the stainless return line a few years back. I couldn't find a replacement so I split a piece of hose and clamped it with 4 hose clamps. It has not leaked since.
Superbowl
Feb 12, 2020
I would braze it.
Why? One or two pulls on the trigger of a mig gun and the nick is fixed and likely stronger that the base wall. All heat is very localized and the steel of the tack is actually melted in to the steel of the tubing. To braze, you have to heat a very large section of the tubing and the braze material never actually becomes a part of the tube steel.
BT Fabrication
Nov 3, 2019
Ontario Canada
My flaring tool is a plumber’s compression flaring tool… and where I live the auto parts ‘loaners’ are often broken, misadjusted or otherwise unusable! I’ll try APD’s compression union approach because once I have the union I have the tools to install it on hand.
Thanks!
plumbing flare tools are not the same!
only use the automotive ones due to pressures and sealing capability of the double flaring tools.
im more surprised that a 2001 ranger still exists and isn't in the crusher. Id probably guess the fuel line is all rusted over and soft all the way down.
better bet is to make a whole new length of it, go to local napa,or wherever and get bulk line and a flaring tool and fuel injection hose clamps. trying to flare old rusty line will keep you running in circles.
Superbowl
Feb 12, 2020
MwTech Inc
Feb 6, 2005
Fishersville VA
Superbowl
Been welding for 30 years.......proficient in MIG, TIg, Stick. so know all about that....
It's the liability of the whole process.
I don't care if he uses bubble gum, its his truck. but rigging a pressurized fuel systems is just asking for issues.
We have no idea his qualifications.....
Besides how is he going to weld it with gas in the lines????
Please explain that process....
Argue with that.......
cosmopedro
Jun 28, 2022
So either buy the proper tools or leave.
"Bend over" yourself wanker,
We’re not ALL experts and pros here, and we don’t ALL have all the tools we need… some of us are looking for advice - ADVICE, not criticism - from someone who’s been there/done that… I’m sorry you have the attitude you have but I’m damn sure not the reason for it. I admit to being a fabricobbler - whether you want to admit it or not you weren’t born an expert either!
I come from farm stock so sometimes the best fix is the cobbled together mess that’s gonna get the tractor back to the barn so you’re not working need-deep in mud.
Have a pleasant life, DDoug.
cosmopedro
Jun 28, 2022
Interestingly, that’s the ultimate plan… it’s winter in New England, we hafta work in the driveway, and I’m just tryna get the Ranger thru to warm weather… the rubber fuel line has been holding well with just a few exceptions, and I don’t want grandson out tryna tighten clamps at night on a side road so I thought a flare fitting might just be the ticket til spring.
I used a borrowed pro-level bubble flare tool for the brake line - which I could get out of the truck easily - but the fuel line is a different story.
Might end up saving my pennies and buying the same tool I borrowed - would be a really nice addition to the shop - but for now might go compression and risk the vibration issue.
Thanks for being more helpful than critical - I appreciate that!!
cosmopedro
Jun 28, 2022
Look up "swagelok" fittings... https://www.superloknorthamerica.com/?gclid=EAIaIQobChMI-s29oM3M_AIVFxOtBh159gnaEAAYAiAAEgKuJvD_BwE
They make "everything" so dig in the catalog for the 8mm joiners.
We use them in critical applications all the time.
I used a ton of Swagelok back in the 80’s… not sure why I didn’t think of them for this application. Prolly cause I live in a small town where the parts folks responded would be “Swage WHAT?” accompanied by a blank stare…
cosmopedro
Jun 28, 2022
Get an Ermeto or some times called a "Bite" type compression fitting coupler. Use for hydraulic fittings 3k psi and will not leak or vibrate loose. A hydraulic hose shop or any one doing hydraulic work should have some.
Look on line you should find plenty. Where are you? I have plenty of them at work.
Southwestern VT… I’ll look online.
MwTech Inc
Feb 6, 2005
Fishersville VA
Well..........I;m going to keep a watch on social media for a kid getting burned to death from tightening hose clamps on a Ford truck...........really??
Weird family love going on here
cosmopedro
Jun 28, 2022
So, when did Practical Machinist become Critical Machinist? I missed that post, I guess… never said it was either a perfect solution OR a permanent one - just tryna hold things together until we can tear into it properly. Which means warm enough to put the truck up on jack stands in driveway.
MwTech Inc
Feb 6, 2005
Fishersville VA
Understand its cold......been there done that.......but you are putting him in a bad situation...
come on man ...common sense....... he's a kid.
He's going to smell gas and trying to help out Grandpa he's going in to tighten that clamp...
Whatever... your life... your family.......if this doesn't make sense to you ..
.I'm done here
