Gumbydammit
- Mar 25, 2021
I have a TR110 rotary on a 2012 VF-1 with a Classic Controller. I wanted to change the Grid Offset or Tool change Offset on the B axis, so I can have the axis to the grid when homing... Currently it is skewed about 30 degrees after homing. (B axis)
I got it to work for the A axis, but for some reason the B axis seems not to change when I change either of those two settings.
Does anyone here have any insight on this? I know I can create a dedicated offset like G56 and call it every time, but I would like to not be forced down that path.
I did a DEBUG and found the correct encoder value I would need is 64862. I tried to enter that value as a positive number and negative number as a possible variant, but no luck. It does say in my literature that the recommended values for the grid offset are between -32768 and +32768. Not sure if that is an absolute, so I tried a few tests with numbers in that range, and still no luck. (No perceptible change of any kind when homing).
Thanks in advance for any insight on this topic.
Cheers,
Gumbydammit
Cheers,
Gumbydammit
