Froneck
- Dec 4, 2010
- McClure, PA 17059
I have a #2L B&S Surface Grinder, works great. I did clean it well, oiled all sliding ares and made sure the self oiler was working. I cleaned and painted all handles after masking the chromed areas.
BUT! when I painted the feed lever/handle the items in the slot that are needed to flip the handle for right to left feed were somewhat beat up. I do have the shop manual but it's not very clear as to how it's supposed to work. If I wanted power feed I simply flipped the lever by hand, cross feed works fine.
I have a few plates 3 X 6" I need to grind to within .005" thickness. Dimension don't matter blank is thicker than finished part but wire EDM service wants material flat to .005, if more it would add cost. Material thickness is 3/8" finished part after cutting to shape is .310".
Would the lever work if I simply put in a fixed flat piece of metal that will hit the stops on the table?
Do the stops have to be the correct height? I'm thinking that if short the trip lever will go over the top and hit the stop mounting screw/nut and jam. My manual show a somewhat angled stop but I have a simple rectangular block. Probably made at some later time.
Simply put what can I do to get the feed working?
