Ox
- Aug 27, 2002
- West Unity, Ohio
No.
The barfeeder does not actually communicate with the machine in that way.
Once you have your feeder macro's set up, the only thing that you would likely be editing on the machine would be the top cut X value so that you don't cut oodles of air one day and crash the tool the next.
How about you go into MDI and key in M70 and single block it.
For best results - change param 6000 B4 (SBM) to 1. This will allow you to single block through macro's.
Then when you cycle M70 in MDI, what program number pops up on your screen?
As you scroll through it - does it jump into a subroutine like I have posted above where you can edit your X values and such?
Before dooing that even - check your library and see what fer 9000 programs are in there, and what they are labeled.
Are none of them labeled "barfeeder"?
If there are 9000's, but no labels, can you scroll through them and see which one(s) has M70 in it?
You may need to edit param 3202 B4 to allow you to access the 9000's.
(Be carefull not to actually edit anything.)
But - no - you doo not need to understand macro programming.
As long as it werks - it werks.
Obviously there is something in there already. You just want to edit in the C axis location is all.
Think Snow Eh!
Ox
Think Snow Eh!
Ox
