Clive603
- Aug 2, 2008
- Sussex, England
Can't see a CNC of any description being viable from a return on investment and time saved basis unless it has plently of other work to keep it going after it's knocked out a months current production ina couple or four days.
Job seems tailor made for an updated something out of the bigger range of multi-head drill presses. Basically arrange an automatic positioning system on the table with a simple pallet type work holder carrying a suitable number of workpieces. With a two head system an annular cutter in the first drill and a long "stepped serial" style tap in the other. Tap would be a special tho'. With more heads you could reduce the load using ordinary serial ones.
Fill the pallet, put it on the table and let the machine do the positioning and drill / tap down feeds. When one pallet is done swop pallets and re-load the first one.
Basically simple end of Lego robotics control really. I'm sure suitable multi-head drill presses can stiil be found at affordable prices. Given how common it is for even small shops to need several holes drilled / tapped in "lots" of the same part I'm very surprised that such things aren't around commercially at small shop sensible prices. Whether all new or conversion kit for the old style multi head drilling machine.
