Best Boring Bar and Insert Style for 6061T6
Natchamp
Aug 29, 2004
So Cal
Gents,
I'm looking for some feedback. I'm looking for the best boring bar for roughing and finishing aluminum. The minimum bore is @ .875 and goes up to @ 4". I will need to rough as aggressive as possible and then get the best finish possible. Can I do this with the same insert or will I need two seperate bars ideally?
No trick contouring required, just some flat bottoms.
Is there a big difference in performance between the different bar manufactures or are they pretty much the same if I go with a solid carbide bar? What about the hybrid carbon/hss bars?
Any particular insert profile to narrow in on?
gregormarwick
Feb 7, 2007
Aberdeen, UK
DCMT inserts are pretty good as a compromise for roughing and finishing. Use a bar with a 95º entering angle, they break chips good at higher feeds and leave a nice finish too.
DCGX is the aluminium specific insert in that geometry.
Carbide bars are a waste of money unless you need to go deeper than 4xD.
Gregor
Wren
Jul 12, 2007
Tuscaloosa, AL
I've been running some ccgp21.51 inserts that I got from curtis(exkenna) and I have been very happy with these inserts for finish and longevity. They were also crazy cheap.
I run them in carbide boring bars from frank mari, an excellent value if you don't need through tool coolant.
The serious production guys here talk about pcd inserts and they sound great, but they never made much sense for me as I am primarily a hobbyist and can run one edge all weekend and maintain tolerance and finish with zero stress.
exkenna
Nov 29, 2007
North Alabama
Nat,
Here's a pic of those inserts Wren is using.
It's funny that this came up. I was going to run a boring bar promo in April for a 3/4" bar and 10 inserts for aluminum for $109.
This insert rocks. It's waaaay upsharp and polished and bumpy. All the things you want in an insert for Al.
Sorry for the big images. Photobucket has decided to screw up their image re-sizing feature.
Natchamp
Aug 29, 2004
So Cal
Thanks guys, all great info.
exkenna, I've been wanting to try some of your stuff, maybe this would be a good time to get some end mills too. Do any of your boring bars have coolant through?
exkenna
Nov 29, 2007
North Alabama
When we go coolant-thru the prices go up and my vendor choices narrow but I can get you a 3/4" steel coolant thru for that insert in the picture for about $100.
USA made. A nice tool.
exkenna
Nov 29, 2007
North Alabama
Psst, Arno makes little if any of their own product. It's re-branded from Cere-Tizit's private label line. They'll deny it till doomsday.
Those are CCGT 32.51 in my pic. I think Wren bought the CCGT21.51's
Wren
Jul 12, 2007
Tuscaloosa, AL
I know they used a g for tolerance, but for some reason I thought they had a P for the upsharp edge. They are in Tuscaloosa and I am in Huntsville though so I'm not looking at them.
I also got some ccmt21.51 for steel from exkenna at the same time that have been performing extremely well in 4140(Rc~30). At his prices, go ahead and get a box of those too.
BobWarfield
Mar 4, 2006
Northern California
Oh good, I hadn't lost my mind. Exkenna, how does one go about ordering them?
Best,
BW
exkenna
Nov 29, 2007
North Alabama
Coolhand: Here's the CNGG, virtually the same.
Sorry for the giant pic, Photobucket's resizing feature is busted right now.
You guys are welcome to call anytime. I work with a lot of forum people at night and on weekends so that doesn't bother me. 256-658-7623
Or email works: [email protected]
Curtis
ARB
Dec 7, 2002
Granville,NY,USA
I popped for a 1" bar and some of these horny looking inserts for a production run in A356. Which is about all I ever turn.:rolleyes:
The bore has always been a bitch to keep in tolerance.
Tonight I lopped the bar in half and put her in the machine. It always makes me feel funny taking a new boring bar over to the saw and having my way with it.
So far the bore has been very stable and the finish is sweet.
Very nice indeed.
Oh, and it runs much quieter.:D
Now to get some turning tools for this style insert.
SND
Jan 12, 2003
Canada
I've been using that type of really sharp insert in plastics too and it does quite well in many of them.
I actually got a lot of stainless work done with a sharp insert like that a few years ago doing bores about .75" diameter. It pulled the chip out of the hole and cut better than normal inserts. I'm not sure if it had a different coating, it had the same deep dish shape and sharp edge, but wasn't quite as shiny. I was surprised it worked in SS, all said it couldn't, maybe I got lucky.
FrankieB
Jun 28, 2019
For me, If you can afford the cost, the best bar out there is a sandvik devibe bar (silent bar).
