Best option for a new 3 phase 240 volt motor for a Bridgeport J head mill?
fourbyfive
May 5, 2022
TX
I recently purchased a Bridgeport J head mill, the previous owner had never hooked it up, likely because the oddball motor on it that required 3 phase 550 volts.
It seems to be in good shape otherwise, and I have a single phase 240 volt to 3 phase 240 volt VFD that came along with it, so I'm looking for a good 3 phase 240 volt motor to replace the old one with.
Any recommendations?
bsg
Jan 17, 2003
Imlay City, Michigan
You did not say if the head is a step pulley or variable speed, the motors are unique to either machine?
I would have the motor rewound for the lower voltage....unsure if you could use a VFD into a step up transformer, that would probably be the cheapest if possible?
Kevin
fourbyfive
May 5, 2022
TX
The head is a step pulley, plan on adding a VFD to get better variable speed.
Haven't found much in the way of 3 phase 240 to 3 phase 550ish transformers :(
Didn't know having a motor rewound was an option, definitely going to check that out, thank you!
Metalurgent
Feb 14, 2013
New York City,
Sent you a PM.
I have one, but I've no idea what model it fits..(we don't have the mill anymore and this was a spare..)
I can send you photos with dimensions.
