Rouzer
- Sep 12, 2018
- Southeastern Part
Hello, I work in a die maintenance shop. these are not mold dies they are metal stamping dies. My question is about flat surface, contoured surface, radiuses, and draw bead repairs. I am trying to research what would be a good stone or series of stones for when I get my weld ground down close, how can I Stone my weld down and not hurt the parent surface? I understand I must use careful handwork to stay off the parent surface but I also know there are tools that can make this job easier. My company provides stones but not the best of stones. One of our more experienced guys uses a stone with oil on his final touch up. I've been reading about India stones and Arkansas Stones I am interested in Arkansas stones but I do not know if these are the best, I did read where soft stones are good for radiuses because they take the shape of the surface. But then you come to the difference of Arkansas Stones between soft hard and translucent, again this is all new to me I'm just trying to learn.
We mostly have heat-treated tool steel inserts but draw beads are disintegrating on Cheap Cast dies with coated surface after galling forms in a given area. So my question refers to soft surface as opposed to Hard coated tool steels(you know, the kind that crack if you weld them without preheating them and then they might crack anyway if you do not wrap them in a fire blanket for slow cooling)
I am particularly interested in stones for radius and draw beads. But I would also like to hear opinions on flat surface repair as well. I would like to know what's a good stone that will cut my weld down fastest and I would like to hear of a good finishing stone that leaves a really good polished finish. I've only been in the industry for 3 years but I've come a long way and I learned everything from hands on. I have a good set of hands on me and I've been given more difficult repairs lately and I just want to be able to do my best. Thanks in advance for sharing your knowledge.
I've probably posted this in the wrong category but please forgive me as I am new, hopefully experienced eyes will come across this. My shop is old school most work is repaired by Weld and hand work. only Shear die cutter blocks are surface ground and shimmed all other cutting edges are welded and worked back with a piloted burr bit.
Sent from my XT1635-01 using Tapatalk
