Best way to shorten a power hacksaw blade
rimcanyon
Sep 28, 2002
Salinas, CA USA
Carbide end mill did the job, thanks for the suggestions. However, even with a carbide end mill, i had stacked five blades to machine in one go (with teeth alternating side to side so that the stack remained flat), and the bottom blade fractured just like the blade I tried drilling with a carbide drill. I think back support is just as important as using the right tool for a job like this. I had set the blades up with a 9/16" gap around the hole location, well clamped on both sides. Probably should have used a piece of scrap aluminum under the blade stack.
eKretz
Diamond; Mod Squad
Mar 27, 2005
Northwest Indiana, USA
Yes, especially with that amount of cutting. Carbide is hard, but it still gets dulled pretty quickly by cutting HSS.
Milland
Jul 6, 2006
Hillsboro, New Hampshire
I'll be curious about how the drilled blades hold up under load. I'd guess the sharp edge of the hole could be a stress riser that might lead to fracture during cutting or even tensioning.
Wear your safety glasses...
