Terry Harper
- Sep 3, 2009
- Maine USA
Hello folks,
Iam new in these parts and not sure if this should go here or elsewhere. First a bit of back ground. Iam in the process of bringing back to life a Wisconsin Model PT engine. I know, I know..... Wisconsin makes those neat air cooled engines. However, a long time ago they made a whole line of water cooled 4 cylinder and 6 cylinder engines. They powered a whole bunch of tractors and trucks and even the Stutz Bearcat used a Wisconsin T-head.
Anyway, mine is a 1575 lb. 6 cylinder Model PT dating from 1925 (5-3/4" bore, 7" stroke) that translates to about 18 liters. It came from a Lombard Model N log hauler. (another story). Incidently that crankcase is 500 lb bronze casting.
Now for my machinist question: I need to cut a new helical gear for the oil pump drive. An original gear was graciously provided to use as a go-by. I have never cut a helical gear - Is it possible to use the gear I have to set-up or do I need to calculate-out everything? Iam a newby so bear with me.
Best regards,
Terry
Best regards,
Terry
