Black Hands - Steering Wheel Forklift Tractor - Is there a fix?
dalmatiangirl61
Jan 31, 2011
BFE Nevada/San Marcos Tx
I'm sure I'm not the only one with a forklift steering wheel that turns your hands black, any suggestions on how to remedy the problem, short of a new steering wheel? Clear lacquer, wrap with tape, flex-seal, plasti-dip? Search engine found nothing, and I've tried nothing. What worked for you?
Gordon Heaton
Feb 19, 2007
St. George, Utah
Had that problem long ago, I rubbed baking soda into the wheel. Kept at it until no more would 'take'. That solved the problem for quite a while. Long shot but might be worth a try. Its worth noting that the rubber coating on mine was a little soft, sorta tacky almost.
john.k
Dec 21, 2012
Brisbane Qld Australia
Tractor steering wheels seem to be around $100 on fleaB ......getting the old one rerubbered /restored is twice that...............anyhoo,nothing to stop you fixin your own .....strip the perished rubber ,and rebuild it with epoxy and cloth...........dont use glass mat ,the fibres will come out into your hands.
dalmatiangirl61
Jan 31, 2011
Bill D
It lives outside, have considered pulling it but suspect that would open up a can of worms.
Gordon H
This is hard black plastic, probably had a gloss finish when new but now matte. Usually wear gloves, forgot today, drove it a few hundred feet, swung it thru a few circles, and my hands looked like I had clawed my way out of a coal bunker.
John K
I've seen the refurbed steering wheels, might be worth it for a show queen, but not a yard dog.
john.k
Dec 21, 2012
Both my tractors have the black hands ....and shirt front problem......a collector said to me that I could buy a new hard rubber wheel for $100.......which would double my investment in both tractors.......I also have an old crane that has /had a tubular steel steering wheel that was coated in black cellulose when new ......unfortunately ,rust inside the tube means its about to fail.
Scottl
Nov 3, 2013
Eastern Massachusetts, USA
There are vinyl lace-on steering wheel covers as well as leather ones. Other alternative would be to clean, sand lightly, and spray with Flex Seal. I used black Flex Seal on the handle of a homemade emergency brush saw (uses Sawzall pruning blade that stores in handle) and it seems quite durable and doesn't rub off.
Another possibility would be to wrap the wheel with bicycle handlebar tape. You might have to get creative as to how to secure the ends.
