Bluing help
Dominion22
Jul 14, 2013
Canada
Need some help with my bluing salts. Using a homemade recipe with caustic soda (23#), sodium nitrate(9#), and sodium nitrite(3#). Everything was going good then salts started to foam instead of boil, at any temp. Change out the batch and went to a 2:1 mixture of caustic soda and sodium nitrate. Same result. Any help or ideas would be greatly appreciated
Dominion22
Jul 14, 2013
Canada
yes I have a thermometer. Started foaming at 260F. Added some caustic soda to bring temp to 285F. Have to shut off the flame to keep from foaming over. Parts blue fine
wyop
Nov 24, 2011
Wyoming
Is there any aluminum involved in all of this? Are you mixing or measuring your salts in aluminum pans?
1yesca
Jun 1, 2004
there are as meany homemade recipe is there are people that blue some work and some don't . if you like the finish then stick with it just may need a bit of tinkering here and there with the mixture or method also there are some recipes in dunlops book of gunsmithing you mite want to cheek out
gwelo62
Sep 17, 2011
ga,usa
I worked with a former RN armourer. He used 50/50 ammonium nitrate and potassium nitrate melted in a steel tank made from a piece of channel. Cyanide was addded if bluing cast steel.
Dominion22
Jul 14, 2013
Canada
How does it go past boiling to superheated ? In the past once it started boiling it just stayed there , needed water every so often to keep temp down. I could turn the flame down to keep it at a low boil. Not sure what changed , I changed the salts out and started fresh with the same results. I’ve added water to get temp down to about 250 and still foams
JohnMartin
Jul 8, 2006
Cumberland, Maine
Superheating is sort of like supercooling, or supersaturation. Sometimes it takes a little “nudge” to get the bubble or crystal to form. Stirring often does it.
