I have a Bridgeport J Head mill that I converted to a cnc. Installed ball screws on the x, y and z. I doubled checked my calibration on all axis and all is good.
I am using the Masso G3 Touch with these stepper motors, https://www.automationtechnologiesinc.com/products-page/nema42-kits/3axisbridgeportkit
Well every time I try to bore a hole in aluminum or steel it does not come out as a circle more like a freehand circle.
Since then I replaced my spindle bearings, shimmed my x and y gibs. I haven't looked at my knee gib yet.
I tried just doing hole boring after I did all the above with no luck.
I am running the spindle at 2720 rpm and using a mister for lube, 8mm end mill and air.
Is there anything I could try or look at?
Thank you for the help, Nathan
