Boring ID jaws
M Code
Apr 4, 2021
I want to clamp 6.5" on ID. So, to turn the jaws do I change the chuck clamp to ID and I turn the jaws till 6.5" ??
is this the way?
latheman78
May 28, 2022
Southern Ca Mtns.
You want to reverse the clamping if that is what you are asking and then cut just a little over size with a positive taper toward the back. How deep are you going?
latheman78
May 28, 2022
Southern Ca Mtns.
You have to bore the jaws bigger than the work piece on a part that size I would go +.005/+.010. I would also bore at a positive taper smaller in the front bigger in the back.
