Boulder, Colorado Hardinge HLV Move
majohnson
Jan 3, 2013
Erie, CO
Purchased an HLV, and looking for a recommendation for a trailer rental. Most of the small utility trailers have expanded metal for the rear ramp. Not to good for rolling a pallet jack up and down. There are some tilt trailers for rent but they have no sides or front panel. Since it a lathe it top heavy any way, so I would hate to tip it over. It would be nice to secure it to the front, that way if you need to brake it not sliding forward.
JBTR
Mar 19, 2020
USA, Northern Illinois
When I moved my mill, I rented a drop deck trailer. That made it a lot easier to get the pallet jack on and off of the trailer; the deck remains horizontal. The one I rented was an Air-Tow utility trailer. It had 4 D-rings on each side at deck level and I used all 8 to secure the machine. That trailer was rated to haul 10,000 pounds I think.
teemfan93
Dec 5, 2015
Check to see if you have a sunbelt near you. They typically rent the drop deck trailers that JBTR referenced. They will also rent you some hydraulic dollies that make moving a lathe real simple
majohnson
Jan 3, 2013
Erie, CO
Thanks everyone! I had look for drop deck and other types, the key was searching for a kneeling trailer. Once I searched for kneeling trlr what I had been looking for came up.
