Folks,
Yes, this is another of those knee powerfeed threads... Except I am just wondering if anyone tried this particular unit :
https://www.precisionmatthews.com/shop/align-z-axis-power-feed/
I hear PM has a good reputation, so it's not like buying one on Ebay/Ali. Thinking of getting one, but first wanted to check with the tribe.
Thanks!
I installed an Align brand power feed Z axis on my Wells-Index mill 20 years ago. Mainly use it to change the table height. I've not had any issues with it. The install for my mill did require me to make a new shaft from the bevel gear of the mill back to the feed. I wanted to keep the original crank handle, and this kit was intended for a Bridge Port.
I don't think PM has anything to do with this unit outside of having their name on it. But these affordable imports have worked well on the machines, as I put one on the cross axis of my mill, the lathe tail stock, and the drill press (required a 10:1 gear box).
I've had these opened, and the internals appear to be well packaged, and a copy of quality designs.
I have a Servo brand on the long axis of the Wells-Index, and it will go into high speed for no reason. These imports give you the schematic in the install instructions, at least the Align and Harbor Freight versions did.
The price is in the same ball park as eBay.
The complaint I have with all these power feeds, including the Servo, the slow speed operation is a very narrow sweet spot on the control potentiometer. The lower torque ones are just an SCR, so they are only working on half the AC power input cycle. The higher torque ones use a TRIAC for speed control, mainly for more current to produce the needed torque.
