techymechy
- Oct 24, 2018
I finally found a Bridgeport M head. It seems to be a newer head with a serial number of M26107. I (unfortunately) have the B3 collet but have accumulated a set of collets: 3/16", 1/4", 3/8", and 1/2". I would like to get a 1/8" collet but I feel that I'm probably pretty set up with what I have (although I'm still looking for collets). I know that Bridgeport didn't track the head numbers, but does anyone know when Bridgeport quick making the M heads?
I'm taking some measurements on the head and I think it is OK. I placed a 3/8" pin gage in a collet and drew it tight. I am reading about .0008" TIR when the spindle is turned by hand (spinning the belt sheave). This isn't as good as my Hardinge TM vertical head which has like .0003(-)" TIR - but I wasn't expecting it to be as good.
My intent is to use this on my Hardinge TM mill. The head came with a 2" overarm that fits my Hardinge mill well. The overarm has a tapered slot machined in it. My mill has a threaded 1/2"-20 hole in the casting that could be used to locate the slot in the overarm. The overarm slot is too narrow for a 1/2" dog point set screw. Does anyone have the proper set screw which was used to locate the overarm? I was thinking of machining the proper taper on the end of a mild steel bolt but was hoping that someone had the real part so I could copy it.
Thanks for your help.
Dave
Dave
