Houston Murphy
- Dec 31, 2012
- United States
Preliminary Layout for the CNC upgrade. All demolition is completed. I cut out 2 large panels from the original steel backing and attached a 3/16 aluminum plate on 1" spacers to allow better cooling properties. 30 amp breaker for power inlet (on/off) to a line filter branch 220 to the ABB VFD (the break resistor will be mounted in a modified Bridgeport heat sink out side the box)48 vdc power source from a 110 leg, additionally there is a 5 vdc source fuse panel, e-stop solenoid, and solenoids for the fans, and home/limit switches. a couple gang bars. Additionally (not pictured) on the operators side there is a breaker panel (marine) with volt meter 30 amp gang and 4 15 amp breakers for the coolant, oiler and to power the dc power supplies
