flutemaker
- Jan 30, 2023
Hello, friends. I have this 1967 Adcock and Shipley Bridgeport milling machine. As you can see in the video, there is a pretty bad play in the spindle, I can spin it and it makes a rattling noise. I have had no luck so far trying to fix this. what could this be?
1 bearings are done and need replacement?
2 gears are damaged? ( I know they were grinding against each other a few times for a few seconds because not engaged properly)
3 Gears do not engage properly and possibly need some sort of adjustment in the high/low gear switch or neutral/back gear switch?
please help! really hoping it's an easy fix since the rest of the machine is in great shape. what can be done? I have seen this fixed in minutes on youtube but it was a slightly different model and don't have the same adjustment screws. Please take a look at the images first because the model I have is less common and may need a different approach.
thanks a lot!
video demonstrating the problem:
thanks a lot!
IMG_1903.MOV
drive.google.com
