Brother Speedio 16k spindle question
Mtndew
Jun 7, 2012
Michigan
Our speedio has the 16k spindle, and we have a bunch of 8620 material that gets a bunch of 30mm holes thru about 1" of material.
Realistically, how big of a solid carbide drill or a replaceable tip Sandvik 870 drill can I get away with without stalling the spindle? Can I expect a 3/4" drill to do the job? 25mm?
I know that the 10k spindles can do a 50mm according to their videos.
I've only ran aluminum and copper in this machine, this is a big job and I wanted to get the cycle down to as short as possible.
Pete Deal
Apr 10, 2007
Morgantown, WV
I don’t think you’ll get too close to that diameter drilling it. I tried I think a 1-1/8” drill in aluminum in mine and it stalled the spindle. I use a 3/4” drill pretty often in aluminum and I think that’s about as big as I’d want to go. I think you’re going to have to drill it 5/8” or so and mill the rest. If you drill it through then maybe use a roughing cutter full depth of cut w/ small step over and just spiral out?
gregormarwick
Feb 7, 2007
Aberdeen, UK
It wouldn't be quicker to use an insert drill? A lot less torque required compared to a solid or replaceable tip drill, good chance you could hit the 30mm directly...
Mtndew
Jun 7, 2012
Michigan
I can try, but I doubt I'll come close to the 30mm size, the 16k spindle doesn't have a lot of torque compared to the 10k.
Finegrain
Sep 6, 2007
Seattle, Washington
Remember you have to hold it in a BT30 toolholder --
All of my insert drills have shanks bigger than the cutting size -- 30mm insert drill thus would have a >30mm shank, which is impractical to hold onto in a BT30 spindle.
Regards.
Mike
dpolseno41
Oct 4, 2013
Sutton, MA
I've been drilling .734" diameter 1" Deep in 1018 with a Walter insert drill on my 16k spindle. I absolultely would not want to go any bigger. I can't even push it hard enough to break the chips. I mean maybe I could but I've no desire to fuck around and find out. 5/8" and under is far more comfortable I'd say.
gregormarwick
Feb 7, 2007
Aberdeen, UK
Regards.
Mike
Not an issue if you go Sandvik, you can get BT30 Capto adapters in C3/C4/C5, and 30mm 880 drills with C4 or C5 backend
Mtndew
Jun 7, 2012
Michigan
We are getting 800 more of these soon, and they each have 8 holes in them so I'll definitely be trying out larger drills and see what I can get away with. I'm leaning toward the 18mm and push it to near the limit.
Thing is, there isn't a percentage load meter that I can see, just a bar graph that changes color as the load gets higher. And that really doesn't tell me much.
Mtndew
Jun 7, 2012
Michigan
If you have to mill it out to 30mm anyway do you actually gain much by predrilling it vs helixing through it?
I do gain a few second per hole because I can take 1 roughing helix pass with my 1/2" end mill. Also a hole allows for chips to evacuate thru so my end mill doesn't re-cut them. It still happens, which is why I'm wanting a larger drill to allow for less recutting of chips.
And if I save 3 seconds per hole on 6400 holes, that's over 5 hours saved during the run.
Mtndew
Jun 7, 2012
Michigan
I am also thinking of getting an indexable high feed mill with TSC and then I can bypass the drill. This is probably the best route.
gregormarwick
Feb 7, 2007
Aberdeen, UK
That's exactly where I was going with that question!
I'm curious what absolute times you're looking at per hole?
I'm thinking I could probably hit that hole in about 20 seconds in that material with a high feed if I had your machine to play with...
gustafson
Sep 4, 2002
People's Republic
Would it make more sense to drill with something you can pound through, like a 1/2 and helical ramp with a ~5/8 EM, interpolate the finish? yes two tools but keep the feedrates up where it is productive.
Rereading that is kind of what you are doing.
I guess my point is that if you stay with tools that you are not slowing due to power you should be going faster
eaglemike
Apr 25, 2014
san diego
Just a quick question, didn't see this mentioned. Is the RPM you are using in the biggest torque zone? Will the tool you are using work there? I've had a couple of jobs in the past that ram better when I took a close look at the torque chart.
good luck!
Mtndew
Jun 7, 2012
Michigan
good luck!
I'm using a 1/2" drill at the moment and it's fine. I was debating on going with a larger drill, but now I think I'll just go a different route.
