Brother Speedio Spindle choice?
kazlx
Nov 22, 2010
Tustin, CA
I'd narrow your choices down to either the 16k or 10K HT.
For a shop only doing aluminum I'd suggest the 16k, but the 10k HT is a beast for a BT30 spindle and will be closer to a 40 taper. Way more torque and comes standard with Dual Contact, although you can get this on the 16k as well. 10k HT is going to be a better job shop/universal spindle and handle larger and longer tools better but I've seen some massive stainless parts done (6"+ thick) on a 16k that I previously wouldn't believe. Honestly, you can't go wrong with either one.
If I were personally buying a Speedio, I'd go 10k HT since I do a mix of materials and I don't care that much about the higher RPM.
The Big+ probably would have been nice.
Laurentian
Mar 2, 2008
Canada
What kind of tool runout are you guys getting with the 27K spindle ? A Speedio may be in our future, but right now we use 20 taper tools with Ibag 40K spindles and are able to keep our single lip engraving cutters under .0005" TIR or better with good preparation.
crossthread82
Apr 1, 2022
Maryland
I don't have a 27k but any speedio with a high quality toolholder i.e. shrink fit, poweRgrip, hydraulic. Should have at most .0002" runout.
BROTHERFRANK
Dec 20, 2013
SoCal
Yeah, .0002" or better with a decent set up. I've gotten them to practically Zero (nearly undetectable with a Mitutoyo tenths indicator) using an ER collet chuck. Was running a .010" end mill in tool steel for a crimping die. Couldn't tell it was doing anything until the cut was over and I could see the nice slots with the coolant off.
