How the LVDT works
well, playing with the connections a bit, I am able to get a much more drastic spread on the amplifier dial. This is great, but I need to figure out what the gage amplifiers outputs and inputs really are.
Anyone good at reading schematics? if so, could you look at the last page in this PDF, and let me know what the input/output connections are for this amp? I have put my meter to them, but have not been able to make heads or tails of the readings.
Since LVDT's require AC voltage to the center coil, I believe that the federal amp must be outputting a very low voltage AC. Sadly my meter cannot read this. 2 of the connections on the amp must be return from the other two coils, and one ground coming out of the amp. Any thoughts?
An LVDT is really just 2 transformers hooked up to oppose each other. The center transformer coil is used to excite the
other two coils. The input is AC, and like any transformer, the output is AC. When the slug, the moving iron part, is
centered between the two output coils, each coil receives the same amount of excitation and they cancel each other
out. When the the slug has been move to a position away from center, one coil effectively gains some windings and the
other coil effectively looses windings, thus the coil with more windings has more output than the other and the output
is the difference between the two coils.
A transformer works by magnetic induction. If there is no iron, there is no magnetic induction. If you have a coil with
ten windings, but there is iron only on/around five of those windings, then effectively five of those winding do not get
get any magnetic induction. The amount of signal you get is proportional to the winding ratio. If a transformer has two
windings in the primary coil, and only one winding in the secondary coil, you get a step-down transformation IE:
10VAC on the input gives you 5VAC on the output.
So lets say you have an LVDT with 100 windings on the primary/input coil and 100 windings on each of the two
measurement/secondary coils - now you put a 10VAC signal into the primary coil, and move the slug to center
position between the two secondary coils. Each of the two coils have half of their coils windings able to support magnetic
induction because the iron slug only covers half of each coil (50 windings). So, each coil puts out 5VAC, and they cancel each other out. Now move the iron slug to the far end of it's travel, and now one coil has no magnetic coupling (no iron), and the other has all 100 windings magnetically coupled and so puts out 10VAC. If you move the slug to the opposite end the other
coil will now put out the same 10VAC but with opposite polarity.
A long explanation, but you should get how it works, and what the signals should be. To know exactly you
will need the windings information from the manufacturer.
Good luck - Paul
