Don’t get too fancy here. Rip it, check the fit by eye and if it closes up nice, use tite bond. If not use epoxy. Clamp per standard procedure for the stickem you use and go on with life.
First cut with right side against fence to cut away all the material to the left of the crack, then move the fence just enough to clean up the right side of the crack. You use the same edge against the fence both cuts. It will likely close up fine. I’d epoxy it, partly because I have it on hand and its perfectly suited to this particular job.
