calculate missing pulley size to achieve proper saw FPM
Peroni
May 18, 2007
Yadkinville, NC
Finishing up a cut off saw that came to me without the original motor and pulley. The replacement pulley is quite small and runs the blade way too slow. I'm not sure how to calculate the correct pulley size I need for the motor.
Motor turns 1725rpm
blade drive wheels are 14.375 dia and 46" apart on center
gearbox ratio is 31:1
original SFM spec for the saw is 60, 90 and 130 using a 3 step pulley.
drive pulley on gearbox is original with approx 6.5", 7.5" and 8.5" sheaves
How would I calculate the size of the motor pulley to achieve the listed blade SFM?
johnoder
Jul 16, 2004
Houston, TX USA
Gear box out put is 55.65 RPM (if we assume for the time being that motor is direct driving gear box)
Band Wheels are 3.763 feet in circumference
55.65 times time 3.763 = 209.4 feet per min
to get 60 you divide that into 209.4 and the result is 3.49 to 1 and 8.5" slow pulley has to be driven by a 2.35 dia pulley - because 8.5 divided by 2.435 makes for the 3.49 to 1 ratio
So that is a start
MaxPrairie
Jul 9, 2015
You have 3 outputs: 60, 90 and 130 sfm. You know the diameter on the drive wheel so you can covert the required rpm using 3.82. Multiply those 3 numbers by 31 to get the gearbox input. Those numbers correspond to your 3 different pulleys. Your 3 rpms must be converted to the 1725 motor output by some ratio. Using this ratio and knowing one of the pulley diameters gives you the other pulley diameter.
Toolmaker51
Jan 13, 2009
Central West Missouri
Bandsawing, and blades in general, don't send the same visual cue like an endmill or drill. The FPM goal is the same, but tremendous gain of circumference and a s**tload of cutting edges just messes up what we're used to judging automatically.
The hints offered are 100% correct. You'll want a step pulley of course; and one more aid. Write the resultant FPM in somewhere visible and durable. Not pencil, felt tip!
I solved the same issue, stepping desired FPM back through wheel diameter, motor speed yaddy-ya. I'm so tempted to work in a jackshaft or a vari-pulley. Flexibility is addictive. If you expect tubing, channel, the structural shapes and solids, among the varied materials, well......
