Can a three phase lathe be connected to single phase of the proper voltage to just turn the lathe and check functions?
JustMe3
Oct 13, 2022
The high plains of Colorado. Fluent in G-code.
I have a recent acquisition of a Clausing Colchester 8000 series lathe (15x50). The building it is in only has single phase power. Where it will eventually reside will have proper 3 phase power. Is it possible to run this lathe using single phase on 2 legs, like a rotary converter, just to power the lathe. This will not be used for any work, just to see how it all turns. Check speeds, travel, threading speeds etc.
The 3 phase taps will accept these voltages: 240, 480, 208 and 575. Equipment in the shop currently run either 220V 3 phase or 440V 3 phase. We either tap off the rotary converter or the transformer sitting next to it.
Thanks for any ideas, suggestions or recommendations.
Shop I was in years ago had a 3 ph lathe on single phase power.
We had to switch in on and be ready to turn it off if it didnt start right up, rotate spindle a little and try again.
Think of it as rope starting a RPC motor. This was an OLD lathe with no electronics of any kind other than the on-off switch and the motor.
The motor should run at about 1/2 or 2/3 power, enough to test functions for your lathe. We used that old one like that for many years.
If you could have the spindle/motor turning as you turn it on that will probably help it to start.
