Jaxian
- Feb 24, 2013
- Santa Cruz
So I have a piece, it's 6" x 7" x 5/8" made of 6061. It ends up with a 1/2" thick feature with a 1/8" hat on the bottom. Kind of rounded triangular shaped. I flip it over put it in a set of milled soft jaws and mill off the 1/8" hat revealing the finished triangular part.
The CAM spat out .040" max DOC and 2750rpm,40IPM. So it goes .005", .045", .085", .125". This is with an Iscar 2" octomill facemill, 4 flute.
This issue is I ran it once and it made ugly noises. It is deflecting the material. Then when it gets to depth and finally shears it off the leftover that was deflecting gets flung. Loud noise, not cool. The finished part looks fine but I did stop and break off one section at the thin front so the next tool wouldn't run into it.
The final part looks great but I can't have it flinging chunks around. Plus I don't want to sit there and break off the extra every time.
I am trying to reduce the machining time on this and it already takes 4 minutes. Maybe use a 1/2" endmill instead and just mill off the full 1/8" at once so it won't deflect as much. Or deeper passes on the facemill or ? Open to suggestions.
Photos of the beat up scraps. The other side looks nice and machined. They are .090" thick at some spots.
