Can you machine a S&W Revolver on a Manual Mill?
akshaykumark
Mar 19, 2023
Hi,
I wanted to know if milling a S&W .45 revolver on a manual vertical mill would be functional and safe.
I love working on manual mills in my spare time.
I don't have much experience machining guns and this is my first time.
I've machined general industrial parts like frames and handles on a manual and complex 5-axis parts like impeller and diffuser on CNC. This is my experience.
Nov 19, 2007
marysville ohio
Hi,
If you have to ask us you probably should not do it. What are you calling a manual mill? Some POS mill drill or a nice tight Bridgeport with a high quality DRO?
kopcicle
Jan 22, 2010
Western Washington
So I'd say yes, with several caveats.
Know your gun steels.
Know your tool steels. You will be making some of your own tools.
Order of operations
Blueprints, drawings, anecdotes, videos, any look inside the factory you can get.
Best to by a barrel or barrel blank.
Wolff Gunsprings.
There is much, so very much more but that is more than enough for now.
kopcicle
Jan 22, 2010
Western Washington
What you mean "us" kemosabe ?
To be sure extreme caution is to be advised when it comes to energetics surrounded by potentially lethal fragmentation. However I fail to comprehend immediate derision, discouragement and less than stellar demeanor.
I'll leave it go with one of my favorite quotes.
"If a man wants to carry two cats home by their tails, by all means let him. He’ll learn things that he might not have otherwise even guessed, and the experience will be one he’ll not soon forget!"
akshaykumark
Mar 19, 2023
A very good Bridgeport equivalent brand (Pentagon) but no DRO. I got a cheap mill-drill too but not planning to make on that.
john.k
Dec 21, 2012
Brisbane Qld Australia
At this juncture we might add,that guns are very strictly controlled in India ,and making your own is likely to be a serious crime........now if the OP had said he lived in the North West Frontier SATA,Id say ,go for it ,and possibly get some help from one of the factories.
GGaskill
Feb 14, 2001
Central AZ
Making the parts would be possible but very time consuming without the various workholding fixtures a factory would use and you likely would need some special cutters or make small changes to the original design to use standard cutters. And then you need to deal with heat treating and other issues.
akshaykumark
Mar 19, 2023
Oh I see..
I wanted to make it because 1) I like manual machining very much and 2) I love the S&W's revolver design.
So no worry about time but yes regarding the fixtures I don't have many. So I'll see what I can do..
maynah
Mar 24, 2005
Maine
It always amazed me the tight fits on the side plates of early S&W and Colt revolvers made with line shaft milling machines.
Scottl
Nov 3, 2013
Eastern Massachusetts, USA
AFAIK the older S&W revolvers were made using multiple machines and fixtures with some parts perhaps done using bench profilers and master patterns.
Not impossible to do on a manual mill but I'm guessing months of part time work for a very experienced machinist and maybe too difficult for a less experienced person. My advice would be to start with a simple single shot pistol first using either a rifled barrel blank or even buying suitable barrel, trigger and related parts etc. as spare parts.
If you want to play with a revolver perhaps start with a gun show frame as a starting point and rebuild it with other parts. Years ago a friend purchased a used heavy duty S&W .357 and converted to a short barreled .45 ACP using various parts including a 1911 barrel which a machinist friend turned into a barrel liner and bored out the barrel to receive it. The rest he did on his kitchen table using mostly hand tools.
Update: I just read that you are in India and I would very carefully check the laws before proceeding. Not worth prison time.
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
I bought a mill and grinder from a fellow who lost his job along with lost retirement for making a handgun at General Motors, so better check all the rules and laws.
Some gun features need special cutting tools, so making a cutter may be due...
NewGunPlumber
Dec 18, 2019
We got ourselves a thermite replacement!!
john.k
Dec 21, 2012
Its not impossible......the Webley Mk 6 revolver has something like 100 small parts ,and tribal gunsmiths have managed to make copies that work OK........There is a utube recently of a SATA smith cutting out Makarov frames with a Koike single nozzle magnetic tracer profile cutter......and there are hundreds of frames there......mass production,not a cottage industry.
