Canned Cycle Drilling on G19 Plane with Right Angle Head
sm2000
Jul 9, 2012
phoenix, az
Good afternoon
I am hoping that someone could let me know why this canned cycle will just rapid instead of feeding to the depth of the hole?
2022 Takumi 3 Axis Mill
Fanuc Oi Control
I have a right angle head setup and my drilling in the G19 plane
O1111(RA DRILL CYCLE)
G20
G00 G17 G40 G49 G80 G90
(T23-2 CENTER DRILL)
G00 G90 G54 X-2. Y0. S1450 M3
G43 H23 Z1.
Z-2.925
X-.1
G19 G81 G98 Y0. X.03 F5.
G80 G00 X-.1
G17
G0 Z1.
M9
M5
G91 G30 Z0.
M30
angelw
Sep 10, 2010
Victoria Australia
Good afternoon
Fanuc Oi Control
G20
G43 H23 Z1.
Z-2.925
X-.1
G80 G00 X-.1
G17
G0 Z1.
M9
M5
G91 G30 Z0.
M30
Hello sm2000,
The following won't affect the operation of your cycle, its just a comment on form. After completing the drilling cycle the drill should return to the Initial Level, in your case X-0.1 without having to specify the coordinate in the Cycle Cancel Block, as you have, with G80 G00 X-.1. Further, any Group 01 G Code (G00, G01, G02 and G03) will cancel a canned cycle; accordingly, both G80 and G00 don't have to be specified in the Cycle Cancel Block, only one or the other.
With regards to your actual issue, take a look at parameter bit 5101.0, it should be set to "1" to be able to drill in an axis other than "Z".
Regards,
Bill
sm2000
Jul 9, 2012
phoenix, az
Thanks, I normally will just put the G80 to cancel the canned cycle but, saw someone do it on another page. I apreciate the suggestion and will take a look at that parameter.
Jashley73
Jan 24, 2013
Louisville, KY
Are you in G94 (feed per time)? G95 (Feed per spindle revolution) would look awfully fast if you were in fact feeding at 5" per revolution.
