TKassoc
- Aug 19, 2009
- Oakland, CA
Cat V80C yard forklift that came out of FMC 20 years ago and has had light use in a fab shop since then. Runs great, this is a de-rated configuration with a massive cast iron Perkins engine. It leaks a little bit of oil here and there. I can get it delivered to you pretty much anywhere in the Bay Area for less than $200. Asking $8500
8000lb. Capacity
2 Stage Mast
Foam Filled Pneumatic Tires
LPG
Side Shift
48" Forks
8000lb. Capacity
2 Stage Mast
LPG
Side Shift
48" Forks
