NAST555
- May 23, 2008
- Gauteng, South Africa
Hi all,
I have a Charmilles 240 SL that I have pretty much figured out. I program it either by hand or with CAD/CAM (Mill program with a modified post) and then use CT expert for the cutting conditions.
I have not quite got into taper cutting with it yet but I have done it on a moly wire cutter with it's own settings.
I will mainly be using taper to cut dies that need a cutting land and then clearance further down for the slugs to fall out.
I tried this for a 10mm square die with rads in the corners and it seemed to work.
(TAPER CUT)
O2
G92 X0.0 Y0.0
G91
G41 D0
G51 G01 X3.5 Y-3.5 T2.0
G03 X2.0 Y2.0 J2.0
G01 Y7.0
G03 X-2.0 Y2.0 I-2.0
G01 X-7.0
G03 X-2.0 Y-2.0 J-2.0
G01 Y-7.0
G03 X2.0 Y-2.0 I2.0
G01 X7.0
X0.5 Y0.5 (Just to get out of cut before turning off comp and going to the start centre again)
G40 G50 X-4.0 Y3.0 (Return to centre start point)
M00 (Remove slug and then start for top square)
G41 D0
X3.5 Y-3.5
G03 X1.5 Y1.5 J1.5
G01 Y7.0
G03 X-1.5 Y1.5 I-1.5
G01 X-7.0
G03 X-1.5 Y-1.5 J-1.5
G01 Y-7.0
G03 X1.5 Y-1.5 I1.5
G01 X7.0
X0.5 Y0.5
G40 X-4.0 Y3.0
M30
Is this the easiest way to do it? Trig it out to see what type of land I cut after the taper and firstly trig the taper amount and program to that? it is roughly a 0.7mm taper per side with my 2 deg taper so it leaves enough material on top for the square straight cut.
The machine has something called "taper expert" which was apparently an option when new. Where is this and will it make my life easier?
(TAPER CUT)
O2
G92 X0.0 Y0.0
G91
G41 D0
G03 X2.0 Y2.0 J2.0
G01 Y7.0
G01 X-7.0
G01 Y-7.0
G03 X2.0 Y-2.0 I2.0
G01 X7.0
G41 D0
X3.5 Y-3.5
G03 X1.5 Y1.5 J1.5
G01 Y7.0
G01 X-7.0
G01 Y-7.0
G03 X1.5 Y-1.5 I1.5
G01 X7.0
X0.5 Y0.5
G40 X-4.0 Y3.0
M30
