Hello. I am trying to bore a 1.8 in dia x 5.25 inches deep in a CNC lathe. The starting hole size is 1.75. The material is 3.5 inch round 4142. I am holding on to .55 inches of the part in jaws. I am using a 1.25 " shank Kennametal bore bar which is the biggest shank my machine can hold. I am using a triangular Kennametal insert with 321 corner. I have the bar extending 5.35 inches. What speeds and feeds would you fellow CNC'ers recommend? How deep of a cut per pass would be recommended?
You didn't aay anything about speed and feed but I'll give you a lecture anyway - don't even
start with rpm. Train yourself to use sfm exclusively when discussing cutting.
Also you need to say whether you are using positive or negative rake inserts. That's important.
5" deep with a one anda quata bar should not be a chatter problem. In steel, for an overall average start point, 400 sfm is good.
I hate -1 inserts. Way too sharp and fragile. -322's will serve you much better.
I'm a fan of negative rake and pushing it. You won't break a chip with less than .015" feed. With a 1.25" bar down a 1.75" hole your biggest problem will be getting the chips out. You do NOT want stringy chips. Make sure they break, and coolant for sure. If nothing else, it helps to lubricate the bore and the chips come out better. If you make sure the bore is open on the back it will help, you'll need to evacuate chips or the bore will be all scarred up or worse, rat's nest, destroy the bore, destroy the insert, potentially destroy the boring bar.
You've only got .025" on a side, that's barely enough to get a nice finish with negative rake. I'd take it in one pass.
That should give you a starting point. You want to cut it, not rub it off.
