checking end mills for runout
wmpy
Dec 16, 2011
I am having problems with end mill runout. I previously suspected the tool holder collet to be the problem. You can read all about that here if you like.
The collet was a problem. I have that sorted now, but I am still getting bad runout. I am now on to suspecting the end mills themselves.
The end mills are 5/16" 3 flute, .060" R carbide mills that I use to rough out a slot.
Please see the picture below for how I am measuring the runout. Does this look like an accurate way to check them? The test indicator in the photo was zeroed on the lowest flute. It's now reading on the highest flute. Repeatedly checking the flutes gives consistent results, so I'm inclined to think that there's nothing wrong with my method, but maybe one of you can tell me otherwise.
I brought this up to the manufacturer and told them how much runout I was getting. They told me that was outside of their tolerance and that they would send me some new end mills. They assured me that they would check these new end mills before sending them, but I am getting the same measurements and poor tool life with these new tools. I can see that they are from the same batch as the originals. So, did the end mill manufacturer fail to check these, or is there something wrong with the way I'm checking them? I am currently looking at other manufacturers since my experience hasn't been great with this one.
rklopp
Feb 27, 2001
Redwood City, CA USA
Your method looks legit in principle as long as your V-block is decent. Your repeatability is a good sign that the method is working. Do you have a known good or any other endmill you can check?
michiganbuck
Jun 28, 2012
Mt Clemens, Michigan 48035
The best collets run out .0002 and if your spindle runs out .0002 you have nearly half thow...and the EM may run out another tenth..
Checking an end mill in the spindle one can sometimes give a 180* twist and get nearer zero.
Back when I was running high precision grinding out of collets I had my common sizes marked for the run-out high side.
At one time I preferred balas collets but even they had to be inspected for burrs before trusting them.
I liked to check EMs out of a close bushing held in a V block.
wmpy
Dec 16, 2011
I did check some other end mills I had, and they were all within a tenth.
wmpy
Dec 16, 2011
I started out checking the end mills in the spindle. I was chasing my tail, though, so I started digging deeper. I'll see if I can find a precision bushing to check them in.
wmpy
Dec 16, 2011
Does it need to be a 3 flute? Swiftcarb makes a 4.
SwiftCarb actually makes a 3 flute like I'm using. I'm waiting on a quote, but I'm afraid it's not stocked.
This is for slotting .530" deep in 4140. I take it in three depths. I started with a 2 flute. It would deflect a bit. Then I went up to a 3 flute for the increased core stiffness. I don't know if I could get away with 4 flutes for slotting. Maybe worth a try?
crossthread82
Apr 1, 2022
Maryland
You're probably looking at these then. In my experience custom tools from swiftcarb only take a couple days. You should be fine slotting with a 4 flute, you're only going 0.5xD.
guythatbrews
Dec 14, 2017
MO, USA
Your check is fine and repeatable just a bit tedious finding the high side. Not terribly surprised you found a bad batch, and they sent replacements from that same batch. I've seen some crazy stuff wrong with cutters. At least you can deal direct with mfg instead of having to go through the distributor middleman, and at least they acknowledged a problem.
I always stick with a 2 or 3 flute cutter for slotting, unless I'm in a jam for cutters. A 4 flute will always deflect. May not be much but it will deflect.
michiganbuck
Jun 28, 2012
QT: GUY; (Your check is fine and repeatable just a bit tedious finding the high side.)
I agree it is an ok/fine check.. no point in getting a bushing for checking only a few EMs.
You say this EM is used for roughing..what process is used for finishing?
wmpy
Dec 16, 2011
I use a 5/16" 4 flute EM to finish the sides and get the final slot width (.323"/.320") I need.
wmpy
Dec 16, 2011
A 4 flute corncob will slot just fine, and much better than anything else I have tried, in a straight path.
I will look for a corncob rougher. I ended up ordering some 4 flute corner radius end mills from MSC to try out because the 3 flute EMs seem to be hard to come by. I will see how well 4 flutes can slot.
CarlBoyd
Jul 16, 2007
Orlando, Florida
Wmpy
2 questions on your measuring method.
1) The picture looks like you are measuring on the relief and not at the cutting edge. Where on the end mill are you measuring. A close up photo would help.
2) The picture shows you are measuring pretty close to the tip, are you on the tip radius?
CarlBoyd
