Good Day,
We just bought a Chevalier surface grinder to our shop.
Chevalier FSG 2460 CNC surface grinder with a Fanuc CNC Express OMC-MCU09506-001 R00
Recently got it functioning and can manually precision grind a workpiece, however due to the immense number of parts that we surface grind we want to use the NC capabilities to provide precise and less labor intensive machining. Since i am a noob at CNC, i could only get it move one direction at a time using simple G01 & G00. I cannot generate a software to perform intermittent surface grinding. Here are some other points regarding this problem / the machine.
I was wondering if there is special Chevalier specific screen on this FANUC control that can help us set the X, Y & total Z range thus informing the machine where to surface grind and by how much.
I have attached a few photos and diagram showing the FANUC control module and the operation we want to perform.
Any advice would be extremely helpful!
Thank you!
View attachment GrinderOperationDiagaram.PDF
- G79 code used for intermittent surface grinding is labelled "undefined" in the Fanuc NC and cannot be used
- The head holding the grinding wheel can only move in the Y & Z direction. The X direction movement is performed by the grinding table that moves between two adjustable limit switches continuously at a given feed rate.
- FANUC & Chevalier both dont have any concrete information on how to perform the surface grinding automatically since this is an old machine, manufactured around 1995
Thank you!
