I recently picked up a clausing 16vc1 drill press and I'm inspecting/cleaning it. I cannot remove the chuck, jacobs no.33. Trying to remove the chuck with a pin spanner and realized the threaded collar on the sprindle is turning and move up and down the shaft as i turn the chuck collar. This is a 1620-10 spindle and the threaded collar appears to have been pinned. One I can see the pin has been drilled and repined, the other side the pin end spins/moves in the hole. I'm trying to find out if it was pinned at the factory, and if so is it through the shaft or two short pins, one on each side into indentations in the shaft. Anyone deal with this problem?
