rons
- Mar 5, 2009
- California, USA
It sounds like a bs question. But if you've done it before you know.
Hundreds of feet of a sharp wire that curls up everywhere and you constantly remind yourself about not touching it or removing it until turning stops.
I have four 2" rounds 1" tall. The straight bore cut is done (green).
The question is whether the tall bit pictured should sweep across with increasing depths of cut?
Or should the yellow and orange sections be taken out separately?
My experience with hand cranking on the miter angle is always a poor finish.
It's also bs when I have to stop/start every 15-20 sec to clear out the nest.
Something I've never tried is running a parting bit at a diagonal. Is that a badee?
The drawing at the top is actual size.
The drawing below is 2x size.
The round is sitting green side up.
The round is mounted in a 3 jaw with reverse action inside the green section.
A tail stock center is applying force to the right side.
I'm doing this today but maybe I should ask first.
