Looking for the clearance measurement on the cone pulley motor drive assembly, bench model. there is a collar that locks the shaft in place. Next to the drive assembly cone pulley After that collar is locked there is a small amount of play that the shaft can slide back-and-forth which gives a clearance to the motor drive wheel that the V belt run on.
was looking for that clearance dimension. if anyone has that in their notes it would be nice to confirm.
Thank you
John C
Sent from my SM-G975U using Tapatalk
Thank you
John C
