Climp vs conventional cutting: speed, feed, finish, life
viper
May 18, 2007
nowhereville
I was talking with Exkenna tonight and thought I would post up to get some more thoughts out there on the comparison in different materials. We are always looking for ways to increase tool life, improve finish, or just go faster.
706jim
Jun 14, 2006
Thunder Bay Canada
climb vs conventional milling
I figure I can go about 5x as fast climbing in alumium and get a better finish doing so. Carbide cutters all seem to work better climbing in steel.
HSS end mill seem to work better CONVENTIONAL milling in mild steel.
Bobw
Feb 8, 2005
Hatch, NM Chile capital of the WORLD
for some strange reason, I've though about this a lot, not so much recently, but I did for a while. I've come up with many theories/hypothesis, I've disproven quite a few, but I think I'm getting better.
You need to get right down into what is happening at the cutter/metal interface. With a conventional cut you are going thin chip to thick. The cutter begins touching the metal parallel with it, so first its rubbing, then the cutter deflects because the cutting edge of the flute has not been able to dig into the material yet, which causes even more rubbing. Then finally, it will dig in and then pull into the cut. So you are really beating the crap out of the outside of your endmill, causing a lot of additional heat, and it seems to leave a whole heck of a lot of burrs. Its basically the same thing as running far too small of chipload on a climb cut, you are rubbing and burning up the outside of your cutter, slowing turning the geometry into that of a drill.
With a climb cut, you are slamming the cutting edge straight down into the material. You aren't going to rub, you aren't going to create extra heat. Sure you are slamming into the material, but how else are you going to cut it? You can either rub it off or cut it off, I'll cut it off.
I'm sure I'm not the only one that has ever played with an axe, When I was 12,13,14 me and my buddy built a 12'X12' log cabin, 7 foot tall, never got a roof on it, but it kept us out of trouble and it was fun. Smack the axe straight down into the wood at a 90 degree angle, and it goes right in. Come at it at a shallow angle, to take off the bark or whatever and the axe would skip right off. Pretty much the same thing just on a different scale, different materials and a different cutting tool.
I hope that made sense?
mrainey
Jul 25, 2004
Spartanburg, South Carolina
The sharpest guy I ever worked for insisted that we climb mill when roughing and conventional mill the finish pass. He thought that the conventional finishing gave less pushoff and straighter walls. We made a lot of nice parts that way, in all kinds of materials.
So, I guess there's plenty of room for debate.
Software For Metalworking
http://mrainey.freeservers.com
Perry Harrington
Oct 7, 2006
Klamath Falls, Oregon
You're right, when climb cutting the bit has the opportunity to spring away from the cut, when conventional cutting the bit is drawn straighter into the cut. But that's what spring passes are for, mill once for roughing, second for finish cut, third time for a spring pass, all climb. It's very prominent with something like a 3/8" with a long DOC.
Metalcutter
Sep 14, 2005
San Diego
Climb across, conventional back. The conventional back is the spring and finish cut.
You can use a faster rpm and associated feed rate climb milling; because the heat from the cut is directed into and absorbed by the material mass, clear to the end of the cut.
When conventional milling the heat is directed to the outside of the piece. When approaching the end of the cut the thin fin type section at the end has little material mass for the generated heat, so the temperature goes high and can dull the cutter.
This is noticable in steel cutting.
Regards,
Stan-
Dave K
Mar 21, 2004
Waukesha, WI
3 passes to rough and finish a wall?:eek:If you conventional mill a finish pass, the deflection pass can be eliminated.
metlhed
Jan 17, 2007
Ohio
That is if you don't leave too much for the finish. :crazy: Climb rough, conventional finish seems to be what they say... :cheers:
